Question about Tenma Power Supply
What kind of connector do I use for the remote sensing connection?
It says 22awg but the connector has a single hole next to a flat rubberized hole. Inserted wire comes out easily, doesn't grip, must use connector?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Tenma Master
  • 1,632 Answers
Yes , use the banana tip conector .
Posted on Feb 19, 2015
Setup proscan tv
Newer tvs have a lot of input connections ( holes) and can be very confusing. With out knowing what kind of plugs you have I will try to help as best I can. First ,if you have a coax cable hook it to the corresponding connector. The coax is a pencil sized cable that has a center wire and a threaded nut. It will screw onto the threaded connector on the back of the tv. If you have RCA cables these will be color coded yellow for video red and white for audio plug these into the corresponding connectors. There may be more than one set of these connectors and may be marked input1 or input2 etc.make sure to write down which input you plug these into.you may also have colorstream cables there are three green red and blue. Some of the newer tvs don't have inputs for these but if yours does plug them into the corresponding colors. Another cable you may have is a s-video cable this is a single cable that has a multi pin connector on each end. Again find the corresponding connector and plug this cable in. The newer cable is called a hdmi cable and is a cable with a rectangular end. This one cable takes the place of the multi-pin s- video cable or the RCA cables. It also replaces the colorstream cables. If you were able to connect all your cables up. Turn on the tv. You may get a blue screen that says no signal. Don't panic take the remote and find the input button. Pressing the input button changes the tv to the various sets of inputs on the back on the tv. Press the input button several times waiting in between each press of the button for several seconds untill you find the input you connected your cables to. If your connecting a vcr make sure you have a video playing so there will be a signal for the tv to find. I'm not sure what a PVR is, but make sure it is playing some thing when you scroll through the inputs on the tv with the remote. Hope this helps.
Jan 03, 2014 | Televison & Video
How to open sony rmvlz620
I have a Sony RM-VLZ620T IR Remote Control.
This remote consits of:
(Outside)
- Two pieces of black plastic cover.
- A red plastic cover on the front of the Remote (It covers the IR leds)
- One piece of gray rubber stripe with fixing patents(!) around on the sidewall of the remote.
(Inside)
- One piece rubber sheet with the buttons.
- One piece circuit board with battery fixer metalic springs.
1. Removing the gray stripe.
Be gently to avoid to tear apart the rubber fixing patents. (There are three kind) It's much easier if you start from the back of the remote near the arc and move forward one by one. Use a small screwdriver or a plastic tool.
2. Opening the cover (together with gray stripe removal)
There are 5 rectangle shaped "holes" (~7mmx2mm) on the both side of the upper black plastic part of the cover (2x5). Use a screwdriver to lift them up (away from the bottom part) one by one from the back to the front.
Hole positions:
1. Near the sony logo
2. Next to the 1,3 channel buttons.
3. Next to the heart and info buttons.
4. Next to the record and stop buttons.
5. Next to the set and power button.
Dec 30, 2013 | Sony RMVLZ620 Remote Control
The volume buttons on my remote for an amp won't work.
try a piece of alum. foil next time before you cut the buttons out---may still work with clear tape over it.
Nov 06, 2012 | Televison & Video
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
How is the external tube for draining outside connected to the dehumidifier. Does the tube insert into the right angle nipple, then the threded end conected to a drain hose?
No. The tube inserts straight into the drain hole. Follow the 4 sets below.
1. Connect a garden hose to the threaded drain hose connector.
2. Remove the drain-hole cover.
3. Push hose connector tightly into the drain-hole on Rear Grille.
4. Press the hose down and make sure the "Arrow" on the tab is pointing upward.
NOTE:
The hose attachment will accept a standard garden hose fitting. Do not over tighten the hose when
connecting it to the hose connector, use a rubber washer and tighten by hand firmly without stripping the plastic threads. Be sure the hose lays flat and has no kinks, as it will not drain properly.
Apr 12, 2011 | LG DH404E Dehumidifier
I WANT TO FIX PRESTIGE CAR ALARM IN THE CAR' AND HOW TO CONECT THE WIRES
Below is a fast installation guide for most car alarm systems. Refer to your manual were needed. Car alarms can be hard to set up and include bands of wiring and sensing elements to instal. Take it step by step and taking after the operating instructions cautiously.
Steps to installing a car alarm system.
1. Mount the siren to a solid surface under the hood. Make sure that you point the horn of the siren toward the ground so that moisture won't affect the sound or horn.
2. Drill a hole through a rubber grommet in the firewall of the car and feed the sirens wire through the hole into the passenger compartment of the car.
3. Feed the power wire through the same hole on the passenger side. Make sure there is enough slack to reach the car's battery. 4. Connect the alarm's power wire to the battery.
5. Put a fuse on the power wire next to the battery.
6. Mount the shock sensor as described in the car alarm's manual.
7. Drill holes in the dash were you will want to place the LED status indicator. Feed the LED's wire through the hole and place the double-sided mounting tape to the back of the LED and place it over the hole in the dash.
8. Find the wires that work the car's power door locks.
9. Connect the door-lock relay to the lock/unlock wires and connect the alarm wire to the relay in the manner described by the tech advisor. 10. Locate the wire that works the courtesy light if the alarm has current sensing.
11. Connect the current sensing line from the alarm to the courtesy light wire.
12. Locate the factory door trigger if the alarm does not have current or voltage sensing.
13. Connect the factory door trigger to the alarm.
14. Locate the starter wire on the steering column below the starter switch. Cut the line and connect the starter disable relay. Connect the starter disable wire from the alarm to the relay.
15. Mount the valet switch somewhere under the dash.
16. Connect all the wires to the proper inputs and outputs of the alarm.
17. Find a sturdy surface under the dash and mount the module under the dash.
18. Use tie wraps to secure the wires of the harness and mount it under the dash.
19. Arm the alarm and test. Adjust the sensitivity as needed.
Feb 17, 2011 | 1999 Nissan Pathfinder
I have a single pole lighted switch with no wiring diagram. it has two screws on one side and three push connection holes, two marked common the other not marked. how do i install it properly?
I hesitate to answer question because the color of the screws is not identified. The holes are not identified which color screw they are next to. You can fill in these blanks when answering if the following information is not complete.
First of all, the green screw goes to bare ground wire and isn't discussed further
Usually a single pole switch has 2 brass-colored screws.
This tells you the wires from old single pole switch can connect to either screw.
Normally the quick-connect holes are located next to a screw >> that screw and the hole are connected. Sometimes there are two holes next to a screw >> and the same rule applies that holes are connected to screws they are next to.
If your switch has two screws and the colors are brass and silver, then that tells you something else.
It says that black-hot-wire-from-breaker connects to brass screw.
And wire-going-to-load (fan, light, motor) connects to silver screw.
If you do not know which wire is which, connect wires, if device doesn't work, then reverse the wires.
Again the quick-connect holes are located next to screw they are connected to.
If your switch has threes screws, then that switch has 2 brass screws and 1 dark screw.
You can wire this device as a single pole by connecting wires to dark screw and either brass screw
Oct 25, 2010 | Cooper Lighting Lighted Switch
I cannot locate the valet switch to disengage the alarm.
    Preparing for the Installation
  1. Step 1 Gather materials. You will need scissors or a knife, crimps, solder material, solder gun, test light, drill, screw bit, screws, tie wrap, double-sided mounting tape and a voltmeter.
  2. Step 2 Read the installation manual that comes with the alarm. Make sure you understand what the instruction manual says. If you purchased the alarm from an automotive store, you can always ask them some basic questions to help you get started.
  3. Step 3 Call the tech support number for manufacturer of the alarm and tell the tech advisor what kind of car you have. Ask what kind of locking system your car uses and what color wire to connect to in order to interface the lock/unlock feature of your alarm,
  4. Step 4 Ask the advisor how to hook up the relay for the door lock feature, what color wire to connect to for the starter disable feature, and how to hook up the relay.
  5. Step 5 Ask how to set up the voltmeter to test the door lock wires.
  6. Step 6 Ask how to access the factory door triggers.
  7. Step 7 Determine where you intend to place the components by referring to the installation manual.
  8. The Installation
  9. Step 1 Mount the siren to a solid metal surface under the hood. Point the horn of the siren down toward the ground so that moisture cannot collect inside it. Drill a hole through a rubber grommet in the firewall of the car and feed the siren's wire through that hole into the passenger compartment of the car.
  10. Step 2 Connect the alarm's power wire directly to the car's battery. Feed the wire through the rubber grommet on the firewall and into the passenger compartment of the car.
  11. Step 3 Put a fuse on the power wire next to the battery. Check the installation manual for the fuse size.
  12. Step 4 Mount the shock sensor as described in the manual.
  13. Step 5 Drill a hole in the dash where you intend to place the LED status indicator. Feed the LED's wire through that hole and place the double-sided mounting tape to the back of the LED and place it over the hole in the dash.
  14. Step 6 Locate the wires that work the car's power door locks.
  15. Step 7 Connect the door-lock relay to the lock/unlock wires and connect the alarm wire to the relay in the manner described by the tech advisor.
  16. Step 8 Using the advice of the tech advisor, locate the wire that works the courtesy light if the alarm has current sensing.
  17. Step 9 Connect the current sensing line from the alarm to the courtesy light wire.
  18. Step 10 Locate the factory door triggers if the alarm does not have current or voltage sensing.
  19. Step 11 Connect the factory door trigger to the alarm.
  20. Step 12 Find the starter wire on the steering column some inches below the starter switch. Cut the line and connect the starter disable relay. Connect the starter disable wire from the alarm to the relay.
  21. Step 13 Mount the valet switch somewhere under the dash.
  22. Step 14 Connect all the wires to the proper inputs and outputs of the alarm module.
  23. Step 15 Mount the module to a sturdy surface under the dash using the drill, screw bit and screws.
  24. Step 16 Use the tie wraps to secure the wires of the harness and stuff it back under the dash.
  25. Step 17 Arm the alarm and test its performance.
Jun 01, 2010 | 1998 Ford Taurus
Front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
May 14, 2009 | ASUS Computers & Internet
Tenma   Power Supply Logo
57 people viewed this question
Top Tenma Computers & Internet Experts
David Payne
David Payne
Are you a Tenma Computer and Internet Expert? Answer questions, earn points and help others
