Question about Dehumidifiers
Pause light is constantly flashing
The equipment was waking fine until about a week ago when I noticed that the "Pause" light kept on flashing. Although still collecting water but I am worried because it was not like this until recently.
  • 2,760 Answers
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Posted on Jan 16, 2015
SOURCE: everything works, but does not collect water
Can I replace the freon? Or do I just by a new dehumidifier?
Posted on Jul 04, 2008
IrishDruid
  • 2712 Answers
SOURCE: Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 29, 2008
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Posted on Mar 28, 2009
  • 52 Answers
SOURCE: Not collecting water
I am still unsure here if your saying that the fan motor is running with the compressor or not? can you clear this up for me.
Posted on Jun 02, 2009
  • 19 Answers
SOURCE: Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Posted on Jul 09, 2009
I purchased this dehumidifier three years ago. It has been working fine up until about two weeks ago. I have the humidity setting at 40%. It is located in my basement which is not very damp. It now runs...
Jeanne, unless your unit is what's called a "Low Temperature" unit (these are designed for basement application) , that may be the problem. In addition, the air intake filter may need to be removed & cleaned.
If yours is not a Low Temp model, raising it up of the floor onto a sturdy table or counter top that can handle the weight of the unit and a full bucket of water, may solve the problem. The reason for this is in a basement, the air temp at floor level is colder than at shoulder level. Non Low temp units struggle to operate at temperatures below 65 degrees. Raising the unit up off the floor onto a sturdy table or counter top, that is strong enough to handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
I hope this information helped you and thanks for choosing FixYa.
Sep 14, 2011 | Kenmore 54501 Dehumidifier
I bought an LG dehumidifier last summer and it worked fine until about 2 months ago. Then there was this constant clicking noice. It seemed like it was electrical with the switch or something. It was...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 22, 2011 | LG LHD45EL Dehumidifier
Dehumidifier not working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | LG LD40E Dehumidifier
Fluttering humidity reading
I would return it as it sounds like part of the circuit is defective.
Anything like this should have built-in Historesis - so it will wait untill a limit is reached before turning on, but also turn off at a lower limit to prevent this wasteful short-cycling.
Aug 30, 2009 | Haier 45-Pint Dehumidifier
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Jun 26, 2009 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
