Question about AutoFry MTI-10X Countertop Ventless Fryer
Error code A07 on an autofry fryer what does it mean and how do I fix it
I turn it off and wait and that seems to help for a short time
Where can I purchanse a new heating element for the MTI-5 auto fry
it is available from the manufacturer on line
or from an appliance repair shop
Oct 13, 2015 | AutoFry MTI-5 Countertop Ventless Fryer
Autofry trips the breaker when i turn it on. do i need a new power cord?
First thing to check would be your circuit. Fryers take a lot of amperage. I am guessing you need at least a 20 amp circuit for this fryer and if you are running it on a 15 amp circuit it is going to pop all of the time.
Feb 23, 2015 | AutoFry MTI-10X Countertop Ventless Fryer
The fan on the MTI Autofry is not working. Everything else working ok. Safe to use until I can get someone in to look at it?
Should get it looked at, the fan can cause other parts to over heat and cause you more problems than just the fan not working. Try to get it to spin by using a pencil (not your fingers) to turn the blades. These fans often stick from grease build up or when going bad from age. Many have a plug connector on the fan and 4 screws holding the frame in place, fairly easy to replace.
Oct 11, 2014 | AutoFry MTI-5 Countertop Ventless Fryer
Autofry a07
Hi , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Jan 13, 2014 | Kitchen Appliances - Others
Autofry Mti-5 - no error codes, was working fine and suddenly won't heat up at all.
we have a MTI-5 Autofry, and the display shows "Basket Can't Find Home". what can you recomend?
Jul 31, 2011 | Kitchen Appliances - Others
I have an error code for ventless autofry of 417
The error code that you have received is from the Temperature Circuit. Please call the MTI/Autofry Technical Support team @ 1-800-348-2976 ext.112 and they will help resolve your issue.
Thank you,
Nov 29, 2010 | Kitchen Appliances - Others
My pitco frialator chips fryer diplaying CFG error
CFG error on controller board can be cleared by resetting the controller back to factory setting and by doing this, all program added after the factory setting will be erased so you have to reprogram them again.
Programming guides are downloadable at PITCO site on
Jul 29, 2010 | Pitco Frialator SG14 Deep Fryer
My Delonghi D14527DZ keeps reading error when plugged in, we over filled it one time but have since let it sit empty but still won't power up.
what this means is that ,The error code indicates that the water or oil or any form of liquid have been located by the temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you will have to do to fix up your fryer is to do what is call general cleaning on it miter so as to allow the lens to communicate with it with this the problem is solve .
Good luck and thanks for using fixya.
Jun 01, 2010 | DeLonghi D14527DZ Dual Zone Deep Fryer
Autofry error message A05 what does it meen
The error message is that the oil is not reaching the set temperature in 16 minutes. Please contact AUTOFRY for more technical support. 1-800-348-2976 ext. 112
Feb 23, 2010 | Kitchen Appliances - Others
AutoFry MTI-10X Countertop Ventless Fryer Logo
289 people viewed this question
Top AutoFry Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an AutoFry Kitchen Appliances - Other Expert? Answer questions, earn points and help others
