Question about Dryers
We recently bought a Samsung dv400 dryer. We - Dryers
We recently bought a Samsung dv400 dryer. We bought the 3 wire cord (they were out of 4 wire). Anyway, we can't get it to power on. The second (smaller) green ground wire is not in any manuals or pictures do I'm not sure if it's right. Please see picture below and let me know if this is wrong our if we bought a dud. Also, I know the terminals are not screwed in in the photo, obviously they were when we tried it.
  • 77 Answers
I would think that the small wire is a control wire as looking to small to be earth does the three core goto plug?
Posted on Dec 13, 2014
  • Rebekah High Dec 13, 2014
    It's a the prong plug as well.
  • 1028 Answers
SOURCE: connecting 4-wire recectacle 14-30r dryer
doesn't matter both are 110v lines but if you want look up to top screw connections the wires coming to those screws are also colored as long as the red and black are to outside screws dryer will work ok
Posted on Aug 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: I need to hook up
The green wire goes to the frame.
Posted on May 16, 2009
erpaalai
  • 999 Answers
SOURCE: Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Eric
Posted on Jun 08, 2009
jsrock516
  • 5911 Answers
SOURCE: connecting 4-wire cord to GE profile dryer
The following link explains how to properly install a 4-wire power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between a 3-wire and 4-wire configuration is how the ground and neutral wires are terminated.
In a 3-wire configuration the wires are terminated together at the terminal block via a ground strap.
In a 4-wire configuration the two wires are independent of one another. Match the corresponding colored wires at the terminal block and attach the ground wire to the ground lug on the equipment cabinet.
I hope this explains it well enough for you. If you still have questions, please let me know.
Posted on Oct 02, 2009
SOURCE: Change 3 prong dryer cord to 4 prong
I have a Maytage Gas Dryer Model SDG515DAWW that Starts up fine but once it heats up ahd the gas shuts off the first time it will not come back on. The blower keeps running but no heat
Posted on Dec 14, 2009
Are all dryer power cords the same except for being either 3 or 4 prong?
They are universal. Just hook the new up the same way the old one was, assuming it was wired correctly.
Feb 02, 2016 | Samsung Dryers
Hi I bought the dryer LG and they sad that it is required at least 220 V. In the apartment where I live. I have 209 V in between two phases could some one recommend me something to do? Will it gonna work...
Hi, Hook it up anyway... it will work just fine!!
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
May 07, 2011 | LG DLEC855 Dryer
I just bought a new power cord for this dryer and the old one has three eyelets and the new one has 4. where do they all go?
heatman101
Oct 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
We just moved into an older home, the 220 dryer outlet is set up for prongs. I went to a hardware store and bought a Magnum 4-wire cord that matches the outlet. My dryer has a 3 wire cord. I removed the...
The red and black are the "hot" wires... white is the neutral and the green gets hooked to the frame of the dryer...
Here is a tip that gives more detail...
heatman101
Aug 28, 2010 | Faber Pro Magnum 605989 Kitchen Hood
We were recently given a kenmore dryer, without a
Here is a tip about hooking up dryer cords...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 09, 2010 | Dryers
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this information helpful.
Mar 17, 2010 | Dryers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
4 power cord to a 3 power cord
You can take off the cord and put a three prong plug for the dryer it will come with 4 wire that connect to the dryer the one that is not coded is the ground wire. when you take off the one you have now it should have a ground connected to it. Or you can get a new receptical to match the one you have now but it would be more expensive. Hope this helped. If not let us know and thankyou for asking.
Mar 16, 2009 | Maytag Dryers
Dryer plug issues
for 3 wire Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
for 4 wire Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Jun 09, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
