Question about Exercise & Fitness
How do you take apart the incline 11i - Exercise & Fitness
Proform xp 550e had a problem with incline...plastic guide piece was brittle and broke apart....hubby made a new guide piece... Incline & incline motor now works perfectly provided you hot wire it! ...
Hi There, I think the motor control board, or MCB, has a couple of Triacs (Transistor looking things) bolted together on that unit. The lift motor plugs in near them. If one of these Triacs shorts or is damaged, it will act "Live" at the connector, and drive up or down constantly, pinching and/or damaging the lift. There are a few causes of constant elevation in either direction....
1) Up / Down key stuck
2) Bad logic signal from the console(unusual)
3) Pinched or damaged console cable
4) Shorted Triac or failing MCB
You can contact jatinah electronics for repair at 75 for these units. Good Luck!
Jan 10, 2015 | Proform Exercise & Fitness
Wireless problem try to installed but Not working Satellite Toshiba - L300-11i serial No. 48249714q
Install the latest drivers from support.toshiba.com. If the problem still exists ( try formatting ) or it should be technical problem. Fix it by taking your laptop to near by service center. Thank You.
Oct 24, 2010 | Toshiba Satellite A135-S2276 Notebook
11I want to get all mobiles service manuals & troubleshooting, jumpering techniques book for free download
you need to prefer phonearena.com there u will get all model phone specifications,price etc
Sep 23, 2010 | Cell Phones
Has ceased to recoil
It sound like the return assembly cord has broken. If you mechanically incline then I suggest you pull apart your unit, but take pictures every step of the way until you uncover and inspect the return assembly. If you are not mechanically incline and since I don't know where you are located, go to the Tunturi website and locate your distributor they will be able to help you with parts availability, pricing and locate a servicer for you.
May 29, 2010 | Tunturi R30 R30 Series Rower
I have a leaking drain pump. The water seams to be comming out of the motor / impeller coupling. Can it be fixed?
more than likely the pump can be rebuilt unless its a sealed pump but highly unlikely if u r mechanically inclined take it apart and replace every o ring and seal if u dont want to tackle it take it to a pump shop probably cost 75 to 125 dollars but if u take it apart pay close attention to how it comes apart and make sure it goes together exactually the same way hope this helps
Feb 25, 2010 | Miele Novotronic Premier 500 Front Load...
Vitamaster treadmill incline doesn't work. Hasn't been used in years. Suggestions??
I had the same problem. I took the thing apart and found a box with several relays in it. When I figured out which one controlled the incline, I tapped on it with a plastic screwdriver handle. Fortunately it was just stuck and that fixed it. I hope you are as lucky as I was.
Paul
Jan 14, 2010 | Exercise & Fitness
Best Server Specification !!!!!!
You can use Linux Base HP-UX 11i Version 3 Server
Aug 24, 2009 | Computers & Internet
Blinkers don't work
if you are somewhat mechanically inclined then try taking the steering colume apart and checking the blinker handle take apart to try and fix the problem or get a new from a scrap yard or your dealer
Jul 27, 2009 | 2000 Hyundai Elantra
Xda 11i pda manual and cd location on the net
Yes, you can download the manuals and software from their website.
Also, you can download the user guide (manual) from the below mentioned link:
O2 Xda IIi Manual
Also, you can visit their website for more info:
www.my-xda.com
Thank you
May 16, 2008 | O2 Xda III
Exercise & Fitness Logo
50 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
