The copier experienced repeated paper jams
I tried to copy but the paper is jamming .
    Master:
  • Office Equip... Master
  • 552 Answers
Pl. mention make/ model and where it jammed. if possible the photo of the jammed paper inside the machine. Also mention the total pages printed in A4 and A3 size.
Thanks.
Posted on Dec 25, 2014
  • 12 Answers
SOURCE: paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Posted on Feb 06, 2007
  • 32 Answers
SOURCE: Sharp AR-287 Copier Paper Jam
most copiers that have lcd screens, should you show you where the paper is. sometimes it may take getting down to look under a couple of guide plates. or just roll some of the rollers to get the paper to come out. all it takes a minute piece of paper to be sitting on a sensor for it to throw the paper jam message.
Posted on Apr 02, 2009
  • 67 Answers
SOURCE: Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Posted on Apr 16, 2009
  • 67 Answers
SOURCE: The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
Posted on Apr 23, 2009
  • 1570 Answers
SOURCE: My canon pixma MP470 printer
Hi
Please inspect again for paper jam located inro the paper tray, in the ink cartridge compartment and rear door of the printer (back door of the printer). If you find the paper jammed, it solves you problem and try to print again.
If not, just open the cartridge door, turn off the printer and move the cartridge using your hand the ink cartridge to the left going to the right and then right to left for 2 times. Then try to print again, also jammed message errror is related to stuck up cartridge.
Posted on Feb 26, 2011
What is mean by call sevices code H5-01 in sharp mx printer
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
May 21, 2015 | Sharp Office Equipment & Supplies
How can solve error H5 in sharp 5516s?
P * C * 14
Oct 04, 2014 | Office Equipment & Supplies
H5-01 without technician assistance
H5-01 means repeated paper jams on the Sharp photocopiers. Once the paper jam is cleared properly, you need to clear the error condition. Put it in 'Copy' mode. Press on the keypad: Related Groups. Printers, Copiers, Scanners &
Jul 14, 2014 | Sharp AR-BC260 Color Copier
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
"Jammed" message
Try new paper.Damp paper causes all kinds of jamming prob.
Jul 13, 2008 | Copystar CS-2030 Copier
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
Mar 13, 2008 | Sharp AR-M350N Copier
51 people viewed this question
jasbo
jasbo
