I need a manual for Model 19E310A13 - Televison & Video
What do I need to do to get my picture and sound on my tv?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Oct 19, 2014 | Insignia Solutions NS-19E310A13 19" LED TV...
Wanting to hook up a sound bar to TV model
The cheapest way of connecting your flat screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 10, 2014 | Televison & Video
Why does my insignia NS-19E310A13 take forever to come on
Hi Louis, Your Insignia is taking longer time to come on, due to some bad capacitors in power supply. If you can open the back cover, these capacitors will be easily visible. Most of the bad capacitors will be bulged at the top. Good luck.
Aug 17, 2014 | Insignia Televison & Video
INSIGNIA NS 19E310A13 after setting channel favorites will no longer respond to any controls
go into the setup menu and reprogram the channels using the controls on the tv itself..if its more than 2 years old, get a new one..repair costs are more than a new set is..
Mar 15, 2014 | Insignia Solutions NS-19E310A13 19" LED TV...
Activation
Best Buy Technicians can help you there. Insignia is their store brand.
Jan 04, 2014 | Insignia Televison & Video
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
