Question about Kenmore Kitchen Ranges
What does an error code dr mean on Kenmore self cleaning oven gas range. I started a self clean and a power failure occured. The door latch appears to be in the lock position but I can open the oven d
I tired disconnecting for a day and also press the cleaning button but still the same.
  • 1,511 Answers
Check your manual for the anser to that problem.
Posted on Jan 03, 2015
  • 1314 Answers
SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Posted on Feb 12, 2008
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Posted on Mar 10, 2008
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
milten1
  • 1304 Answers
SOURCE: maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
Posted on Oct 03, 2009
mrbobfixit
  • 259 Answers
SOURCE: Oven sef clean latch locked but door is open and I
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Posted on Jun 16, 2010
I have a Kenmore Range Model 95012102. After canceling the self cleaning oven process the code E1-F5 appeared on the display panel and the oven remains locked.
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
The part number for the latch asm. which includes the switch is W10107820
GENE
Sep 05, 2011 | Kenmore 95012 / 95014 Electric Kitchen...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Error code E-1F5- came up on self cleaning oven before cycle was done what does this mean door wont open
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 20, 2011 | Whirlpool 30" Self-Cleaning Slide-In Gas...
Trying to self clean oven, error code F5 E1 alarm set off in the first few minutes of the cleaning cycle
F5
lock
1.
If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 31, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
I have a Kenmore Range 95802000 and when I go to self clean it gives me an error E1 F5 .. What do I do.. IT wont lock or start cleaning. Thanks - Toni
Check the door switch and latch switch for continuity as described. If you need diagrams or illustrations of your specific model try this link
Replacing oven ERC
There is also a link to show you how to use a multi meter
Oct 15, 2010 | Kenmore Kitchen Ranges
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
I set stove to self clean for the oven and received E1 F5 error
F5 - E1 Self clean latch will not lock.
1. If door latched:
  4. Re-apply power.
Please tae the time to rate this solution
Dec 30, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Dec 13, 2006 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
98 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
