Question about GE Cooktops
How do I change a burner on a GE Model JP939WH1WW Cooktop
I had the right front burn on my electronic glass cooktop go out. The error codes it gave indicate that it is bad. I would like to get some idea of how hard it is to replace the burner myself and hopefully how to do it.
  • 102 Answers
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
Tip
How to fix GE cooktop error code F116
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below:
ApplianceZone.com Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD
ApplianceZone.com Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
GE Profile Gas Cooktop, Model JGP975SEKSS
Buy the Burners for my 36" GE Gas cooktop.
Jul 09, 2008 | Cooktops
Cooktops Logo
126 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
