Question about HP Photosmart C4280 Aio Printer
Carriage jam After opening and cleaning, a black l shaped plastic piece which was behind the card reader, is not fitting. Help
  • HP Master
  • 15,557 Answers
How big is the piece? Are there any things missing off the printer near the card reader slot?
Posted on Dec 13, 2014
Clear carriage jam
Ok guys I was struggling with the same issue for HP 3520, so I opened the cartridge access door and press down on a small black piece of plastic (that holds the carriage in place) once you press it there will be a slight click sound and thenn move the carriage to the right hand side.
Now close the lead and click ok the clear message.
You should be ok.
This method worked for my model.
You must have the power turned on otherwise it won't move.
Aug 29, 2012 | HP DeskJet 3520 InkJet Printer
The "paper jam" message stays
Yes you may think you have cleared the paper path but there is still a small piece of paper stuck around the jam sensor arm..
look into the machine and when the carriage moves to the centre for you to change the ink tanks, pull out the power lead. observe where the carriage has stopped and now push the carriage all the way to the left. Where the carriage was is a black panel with a lot of little rollers in it. There is a small slot in the panel and thats probably where the critter is hiding.
good luck with a long L shaped opened up paper clip... get my drift?
Aug 04, 2011 | Canon PIXMA MX310 All-In-One Printer
During startup the drive belt slips and gives an error
Open the printer's door and look for the print carriage. It's the platform that moves back and forth over the paper, probably where you put new cartridges. Unplug the printer, and check this belt and its pulleys to see if it's either broken or possibly covered in ink. The drive belt will be black and have gear teeth on it. If you see a metal or plastic ribbon, that's more likely the encoder that let's the printer's computer read the position of the carriage. See if you can nudge the carriage and make it move a little; it may simply be jammed. Check the carriage's moving path and make sure it's not obstructed. Any other problems would probably best be handled by Epson.
Feb 27, 2010 | Epson Stylus R380 InkJet Photo Printer
Officejet G85
For the paper jam you remove the back cover and clean the 4 rubber rollers with alcohol, you can rotate the rollers forward while you clean. For carriage jam you start by cleaning the encoder strip that runs across behind the carriage unit, the clear strip with black bars on it, you can wipe with a Q-tip damp with alcohol. If no help you may need to take apart and clean dried ink off of the service station on the right.
Feb 01, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Carriage jam open door carriage jam and then press OK to continue
You would be absolutely amazed how small a piece of debris can cause that fault. Use a flashlight and look carefully for any piece of debris and remove it.
Get some "canned air" from any computer or office supply store and blow out the interior of the printer thoroughly.
Nov 25, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7580 Paper Jam made piece pop up in the way of carriage
Please go through the web link given below and follow the instructions to clear the paper jam without damaging your printer.
bc://bt/QUEvVGVybWluYXRvciBTYWx2YXRpb24gMjAwOSBDQU0gWFZJRC1GRUFSLzg4OTg5NDI5OC8zMzQ2MmI4YTEyZDQ4MzIxNDVmOWVkNGQwNTFiZjBjM2ZkNmFiMzZhL1pa
May 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Two choices; 1. Take the machine apart and take the roller out and then bend back the little follower.
2. Break the offending follower off and hope the paper still feeds through OK.
Apr 28, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
HP 6110xi -clear carriage jam
LOOK BEHIND THE CARRIAGE IS A SEE THROUGH CALIBRATED RIBBON WHICH NEED TO CLEANED, IF IT DOESN'T WORK THE SENSOR BEHIND THE CARRIAGE MUST BE CLEANED
Nov 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
"Clear carriage jam" persistent error...
i'd say that when doing surgery at this level, it's always handy to have the guide to surgery for printers.
I'd say that this patient is muerto.
Aug 07, 2008 | HP Photosmart C4280 Aio Printer
Carriage Jam
I tried all these steps and it still did not work was ready to throw the printer out from frustration. Instead I traced what I did when I had the jam. I believe if the factory can fix it so can I. My printer is now working and it was so simple yet HP does not tell you how to fix it.
Jul 20, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Photosmart C4280 Aio Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
