Overflowing soap dispenser
Have tried bleech and c l r, threw clean cycle. smaller loads. smaller amounts of soap (HE). still over flowing water at front of soap dispenser
  • Brad Brown Dec 13, 2014
    Hi scott clifton, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the make and model number?
    Problem Solver:
  • 5 Answers
Slow down the inlet water with a restrictor
Posted on Dec 13, 2014
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
Bleach dispenser
Check water flow INTO the dispenser. This happens during the
cycle to dispense the bleach evenly through the load.
Jul 22, 2014 | Frigidaire Washing Machines
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet and water is over flowing and coming out the soap drawer. I have tried flushing out the opening with a hose and it still over flows. Any suggestions?
Hi, W/D here.
Remove the dispenser tray. Clean the overflow caps on the underside of the dispenser, and clean the tubes from the dispenser to the hose to the drum. In the more serious clogs, you may need to clean the hose to the drum.
Best regards, --W/D--
I have water flowing out of the soap dispenser on my front load model wm1815cs. How can I fix it.
Sounds like the dispenser is clogged with soap residue -- needs cleaning. First, try just pouring copious amounts of water in it and running something akin to a pipe cleaner down through it.
If this doesn't work, let me know.
Charlie
Jan 09, 2011 | LG WM1815CS Front Load Washer
It will not dispense the fabric softener.
Hi
You'll need to clean the dispenser by removing it. Use white vinegar and spray then spray the dispenser & agitator with it too. Use hot water after a minute and vinegar will wash out the softener. Try using a soft brush to clean it. Try running a cycle with hot water and bleach (use no soap). Avoid using large amount of soap. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Siemens WFXD8400UC Front Load Washer
Fabric softener does not despence
Hi
Daniel
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WFR 2460 Front loader
We went through the whole "clean the soap dispenser" deal and results were the same. Exploratory surgery revealed that the Prewash hose (for lack of better term), which connects from the top of the drum housing to the right side of the dispenser drawer (facing the machine)was completely clogged with gunk. Especially strange since we don't prewash hardly anything, ever. The hose that connects the bottom of the detergent dispenser with the side of the drum housing did have a lot of buildup, but I do not believe it was the cause because this was only happening on the rinse cycle. I also found the flow meter was frozen up.
Jun 27, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
