Question about Photography
Camera wont let me rewind film
Iv tried to rewind the film back so i can open the camera without ruining the film , but the lever is stuck and wont let me wind back
  • 15,557 Answers
Get a heavy coat and zip it shut, take it and the camera into the darkest room in your home, put the camera in the coat and reach through the sleeves backwards, Grab the camera and open it and take out the film, wind it back into the cannisteer by hand.
Posted on Dec 13, 2014
How do I remove film from the camera?
wow a film camera!!!! , didn't know any of these still existed (less than 60mm) anyways you'll need to rewind the film back into housing , this is done with tiny crank on top of film advance wheel (don't go to fast !!!) slow and steady wins the race!! you'll also need to activate the shutter release lever (around the crank someplace) DO NOT OPEN CAMMERA TILL YOU HAVE REWINDED ALL THE FILM INTO HOUSING !!!!!!!!!!!! it will ruin all the photos
Dec 01, 2015 | Ricoh KR-5 SUPER II 35mm SLR Camera
Film advance lever wont move
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Jan 29, 2014 | Minolta X-370S 35mm SLR Camera
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
How can I open the back of a canon AE-1 camera if the rewind button is missing?
You can open the back by pulling up on the rewind lever - but if there's film it'll be ruined since you apparently have no way to rewind it.
If you intend to use this camera, I'd spend the money to get it repaired. If not, ebay it off to someone who will, as it's useless in his condition.
Jun 29, 2011 | Canon Photography
The rewind button on my diana camera is stuck OUT - as well as that I can't rewind my film as the rewind lever is stuck - can you please help?
Take your camera to photo developer who has the dark room. They will open your camera in dark room and remove the film without any damage to it. Once film is out you can see whats actually the problem, it can be gear tooth misaligned or something.
May 08, 2011 | Lomo Diana Mini 586 Film Camera
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Cant open camera to get film out
Hey stupid 01,
To open your camera back you need to pull up on the rewind lever knob (on the left side of the camera with the lens pointing away from you), and the camera back should pop open. Before you do this make sure your film has been rewound back into the film canister or you will ruin your images.
Sincerely,
Allan
Go Ahead. Use Us.
May 11, 2008 | Cameras
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Photography Logo
128 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
