How do I get assembly instructions for a Carter Fireplace as the box contained no instructions
I recently purchased an electric fireplace in a sealed box that came with no assembly instructions. Where would I go to find these? I have searched everywhere!! HELP!!!
  • 656 Answers
Find the brand and model, then try typing brand etc. into web browser, most all manufacturers have sites for their products. So just type it in and give it a try. If you had posted the brand I may have been able to direct you to a link that would help you.
Posted on Dec 13, 2014
  • 1 more comment
  • Kathy Ison
    Kathy Ison Dec 13, 2014
    Hi Daryl, It is a Carter Fireplace -- Product code 0-08487459-3 and UPC code 817266010243. Any information you can get would be of great help!!!!!!! thanks
  • Daryl Gleaton Dec 14, 2014
    Found this link for your stove, just copy and paste into web browshttp://i.sears.com/s/d/pdf/mp-tc/spinpdf/spin_prod_1183768212er.
  • Demar Brown
    Demar Brown Feb 17, 2015
    stove? lol
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
Jan 18, 2016 | Classic Flame PRO 36EB110-GRT 36 Inch...
Need manual for whalen fireplace 41 long model#sf103-23
Search Results
    [PDF]Harrison Fireplace Console Model # HRSFP-30I - Whalen ...
    www.whalenfurniture.com/...instructions/Whalen_HRSFP-30I_Instructio...
    Harrison Fireplace Console. Model # HRSFP-30I. ADULT ASSEMBLY AND SET-UP REQUIRED. If you have any questions regarding assembly or if parts are ...
    [PDF]User Manual - Whalen Furniture
    www.whalenfurniture.com/...instructions/AI%20WS03061533%20Engli...
    Please call our customer service number and have your instructions and ...CATALOG: GRANTVILLE 64'' Media Fireplace (WS03061433/WS03061533).
Nov 28, 2015 | Cameras
Purchased a great world model swe071 electric fireplace. How do you control the feature to make the flame colors change automatically without using the remote every few minutes. Lost manual
I bought a great world ltd swe067b electric fireplace ... - Fixya
www.fixya.com/.../t25420081-bought_great_world_ltd_swe067b_electri...
Feb 12, 2015 - i bought a great world ltd swe067b electric fireplace a couple of months ago.it wont ... Purchased a great world model swe071 electric fireplace. Howdo you control the feature to make the flame colors change automatically ..
Oct 25, 2015 | World Heating & Cooling
Need blower for model #crhfd400rt-m-m gas fireplace
PDF]BLOWER ACCESSORY - Home Depot
www.homedepot.com/.../0e104dad-8f0d-4383-aa50-11...
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
Lowe's STYLE SELECTIONS Blower Fan for Gas Fireplace ...
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
Cedar Ridge Hearth Crhqd250t - Sepeda Ontel Klasik Vector
efratoium.xyz/cedar-ridge-hearth-crhqd250t/
Feb 26, 2013 | Heating & Cooling
I bought a PROlectrix Balmoral electric fireplace but there are no instructions with it...
Hello! Do a search.. there is one company.. something like smgeneral that has instructions you can download free.
Looks like the instructions are easy enough, but it will take two people unless you can support the fireplace somehow. Most of it is safety. I bought one of these, but have not opened the box.. just saw your problem and remember seeing directions. Search was: prolectrix balmoral electric wall fireplace and found instructions. Good Luck!
Sep 30, 2010 | Fire Sense 02691 Black Wall Mounted...
Electric Fireplace - flame goes down instead of up
If you assembled the unit then it is possible that you have the motor installed in reverse. An AC motor should not do this as AC does not care about reverse polarity.
Feb 12, 2010 | Dryers
Where can I get a napoleon gid3014n gas fireplace insert product manual
I emailed the manufacter and they emailed an attachment containing the installation instructions. The fireplace insert hasn't been made in 9 years.
Dec 23, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
