Question about Dishwashers
Dishwasher motor makes a buzzing sound and will not wash but drains fine with no noise.
  • Brad Brown Dec 13, 2014
    Hi L hulme, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the make and model
  • 77 Answers
Sounds like pump motor stuck
Posted on Dec 13, 2014
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
Loud continuous buzzing noise while dishwasher is running
Hi hope you are well have you checked that the dishwasher isnt touching your units either side their should be a slight gap either side you will get this noise if it is touching anything at the sides or pressed up against something at the back if this is not the problem.
If it is making the noise through most of the wash cycle the the chances are it isnt going to be a pump on the way out the only other thing it could be is the motor that turns the spray arms around and it could be either the top or bottom usually if you can get to the motors you can oil the moving parts as sometimes thse get dry over time.
Try the first sollution first try moving the dishwasher a bit and then try it again if still noisy then the chances are one of the motors has got noisy on the spray arms it wouldnt be the pumps as the noise continues through most of the wash.
Some times just moving the dishwasher will recitfy the problem as the same happens with fridges and freezers if it has been knocked and is not level or is touching a unit you will get a slight vibrating noise so try moving it a bit.
Let us know how you get on
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
Whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Mar 12, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
Hi!
The noise is coming from the power board may be a loose connection or a cold solder joint
Mar 14, 2009 | Kenmore 24 in. 16352 / 16354 / 16359...
Does not drain
The light buzzing of the motor doesn't mean the pump is in good condition and actually is being driven by the motor, in fact a seized synchronous motor can make a convincing buzzing sound and not burn out for a long time. The pump intake could be blocked...
If the symptoms indicate there could be something wrong with the pump then visual confirmation is required and not merely the assumption.
Jun 18, 2017 | Kenmore 24 in. 17052 / 17054 / 17059...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
