Question about Quantum Pride 600 XL Power Chair - Used Electric Wheelchairs
My quantum 600 keeps turning off, it will go for 60 secs after pushing button by feet
Pushing the button I think it is a fuse reset button it's down by my feet on the front
  • Quantum Master
  • 9,742 Answers
It's a circuit breaker. If it keeps popping out , that is an indicator that the motors are using too much current or the controller has a short in it. You need to have it serviced to find the ultimate cause of the over current draw.
Posted on Dec 13, 2014
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Resetting service indicator
1) Make sure ignition is off
2) push & hold in left button (daytrip reset)
3) while holding in, turn ignition key into pos.1
4) keep holding button pushed in while "Test 1" appears in display
5) after a further approx. 5 seconds oil service inspection will appear (whichever is due)
6) release button when oil service/inspection are displayed
7) pushing and holding in the button for appr. 5 secs will reset the service interval
8) release button and switch off ignition. When restarting interval should be reset
hope this works.
Sep 07, 2014 | 2014 BMW X1
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Wont turn on pressed the reset when it froze and now it wont go back on
Press the Power ON/OFF slide button.
To power ON, push Slide UP & hold for 5 sec's
To power OFF, push Slide UP & hold for 5 sec's
If no go,
Use the Stylus and push into Reset hole, at bottom of device.
(not on back side, but at the bottom, where there is a single hole.
Press and hold for a second or two, or until it turns off/on.
Pushing Slide DOWN, put's it HOLD mode (make sure the slide
switch is Not in the Down position) is probably in Hold mode?
I've had this problem before and finally realized that I was putting it in
the hold mode every time, by pushing the Slide Power button, down.
Instead of UP.
May 24, 2011 | Mach Speed T3000 MP3 Player
My router isn't working. all the lights stay on
Make sure you're using a paper clip while pushing the reset button. Also the router has to be on while you're pushing it. Hold down the reset button for at least 30 secs-1 minute
Jul 09, 2010 | Linksys Wireless-N WRT150N Router
TLP 3842 Thermal Label Printer: Need to know how to properly reset printer when pu...
turn the printer off then push the reset button in back then turn on and keep holding for 60 seconds and then release. this defaults the print server only, not the printer.
May 17, 2010 | Zebra TLP 3842 Thermal Label Printer
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
Can't get the Change oil light off
Turn the key to the on position and press the gas peddle down to the floor 3 times within 5 seconds,then wait 10 seconds. Turn the key off then start the car,the light will be off :)
Aug 28, 2009 | 2000 Pontiac Grand Am GT
What do these codes mean on 1994 Cadillac Eldorado -A012 and A047
Sound like you have a bad cv "constant velocity joint " REPLACE.
The first thing you need to do is to clear your old codes then drive
and see if they come back .
1. Re-enter back into the climate control panel and after all the codes display the display will stop at PCM?
2. Push and release the FAN UP (^) button on the climate control panel and you will see PCM DATA?
3. Keep pushing and releasing the FAN DOWN (v) button until you see PCM CLEAR CODES?
4. Push and release the FAN UP (^) button and you will see PCM CODES CLEAR?
5. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
6. Push and release the FAN DOWN (v) button and you will see IPC?
7. Push and release the FAN UP (^) button on the climate control panel and you will see IPC DATA?
8. Keep pushing and releasing the FAN DOWN (v) button until you see IPC CLEAR CODES?
9. Push and release the FAN UP (^) button and you will see IPC CODES CLEAR?
10. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
11. keep Pushing and releasing the FAN DOWN (v) button and you will see ACP?
12. Push and release the FAN UP (^) button on the climate control panel and you will see ACP DATA?
13. Keep pushing and releasing the FAN DOWN (v) button until you see ACP CLEAR CODES?
14.Push and release the FAN UP (^) button and you will see ACP CODES CLEAR?
15. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
16. keep Pushing and releasing the FAN DOWN (v) button and you will see SIR?
17. Push and release the FAN UP (^) button on the climate control panel and you will see SIR DATA?
18. Keep pushing and releasing the FAN DOWN (v) button until you see SIR CLEAR CODES?
19. Push and release the FAN UP (^) button and you will see SIR CODES CLEAR?
20. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
21. Push the AUTO button to get out of diagnostics.
22. Turn ignition OFF for 15 seconds.
23. Re-enter diagnostics and see if any history codes re-appear.
Mar 27, 2009 | 1994 Cadillac Eldorado
Lights blinking normal wash, heat dry, and hot wash, ?
Keep pushing the buttons (any) including reset,hold them down for a few minutes and the system will reset its self. Just pushing the reset will not do it,push all buttons in turn
Feb 11, 2009 | GE GLD4260MSS Built-in Dishwasher
Quantum Pride 600 XL Power Chair - Used Electric Wheelchairs Logo
122 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
