Question about DeLonghi Coffee Makers & Espresso Machines
Mo steam or hot water
I have purchased thermal fuse and fitted in my delonghi 6700 the old one was open circuit stopping my steam being made for frothing milk it worked for one cup and went open cicuit again with new one fitted if I bye pass this thermal fuse the steamer works fine but I am concerned that the element must be getting to hot causing this to happen it makes coffee with no problem its just when you use the steam side it does not work and keeps making thermal fuse go open circuit the element reads 50 ohms and the coffee thermal fuse is fine even though it is located close to steam thermal fuse could you please help me with this fault and let me know what part is needed to rectify regards steve
  • 691 Answers
Check that the temperature sensor is working correctly. If it is covered in scale or otherwise faulty it may be causing the machine to leave the heat on longer than it should. If you have a multi meter use it to monitor the resistance through the ntc (providing the machine uses this kind of temperature sensor) as the temperature rises. It should be fairly linear. Try cleaning the sensor or replacing it. Also check to see if the heat is turned off when the water reaches the correct temperature.
Posted on Dec 14, 2014
Testimonial: "Hi thank you for getting back to me there is only one sensor on the element that I can see does this control the coffee temp as well as the steam temp as the coffee temp is working fine"
  • Inky Fingers
    Inky Fingers Dec 15, 2014
    The steam and hot water are usually made in the same boiler. An air gap is left above the water level and the water is boiled to fill that gap with steam. If there is only one element then that element must be the one switched on to produce the steam. The temperature sensor will be used in conjunction with a pressure sensor to control the water heater. It is quite likely that as the steam pressure drops and the heater is switched on to rebuild the steam that this is when the thermal fuse blows.
    There may be too little water in the boiler; allow machine to fill and heat for coffee then turn it off and allow it to cool. Purge all steam from the boiler. Check the water level in the boiler. Clean level probe(s). If water level is low check fill pump operation and water flow. There could be scale or obstruction reducing/stopping water flow.
    Use multi meter to check element turns off at correct temperature. If it does, check operation of steam pressure sensor. Sensor may be calling for heat to produce steam when pressure is already sufficient.
    You may wish to replace the temperature sensor and pressure sensor/regulator as a precaution anyway.
    I believe you are in the right area of investigation but just need to pin down the fault to a particular component. Let me know what result the above gives.
    There is likely just one temperature sensor - it may be an NTC type or a capillary thermostat type. The thermal fuse as you know is the secondary defender against overheating.
  • Inky Fingers
    The steam and hot water are usually made in the same boiler. An air gap is left above the water level and the water is boiled to fill that gap with steam. If there is only one element then that element must be the one switched on to produce the steam. The temperature sensor will be used in conjunction with a pressure sensor to control the water heater. UIt is quite likely that as the steam pressure drops and the heater is switched on to rebuild the steam that this is when the thermal fuse blows.
No hot water from the delivery pipe, nor steam for cappuccino
If the machine is constantly showing "in Preparation"
The fault lies in the boiler circuit.
Either :-
Steam element is open circuit. (7332212600)
Temperature sensor is faulty (5232105100)
or
The Thermal Cut Out (TCO) (5232105000)
fuse has gone open circuit.
All three of these can be tested with a multimeter with the
machine SWITCHED OFF and unplugged !!!!!
If you do not know what a multimeter is then I suggest that you return the machine for repair as their are DANGEROUS VOLTAGES within the machine which will KILL you.
May 05, 2016 | DeLonghi Prima Donna Avante ESAM6700...
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Why won't the steam function work on my brand-new out of the box DeLonghi Magnifica Espresso Machine?
The steam heater is probably not working. Check your manual to see if there is a fuse or reset switch for it. If that doesn't work, return the machine to where you got it for an exchange.
Aug 30, 2015 | DeLonghi Magnifica Coffee Makers &...
The iron is still working but the water not hot
There is most likely a build-up of minerals around the steam holes. Minerals are in ordinary tap water. The coat the heating surfaces, act like an insulator and prevent iron from getting hot. Clean the hot plate with a fine needle or other fine object and then put in a mixture of vinegar and water and let it steam out. To prevent future mineral build-up, use half distilled water and half tap water. If you can't get distilled water, use ordinary drinking water you can buy from your supermarket (it also cheaper). Don't use 'all' distilled water as it boils (steams) at higher temperature and could ruin your iron. Good luck.
Jan 20, 2015 | Rowenta DG5030 Iron
My delonghi caffee nero machine-the coffee maker wont work,the hot plate doesnt warm either(although the lights come on. the espresso maker part works fine. Someone mentioned there is a fuse which blows...
If expresso maker part works, the fuse is ok. I think that the resistence of the hot plate is interrupted. You must use the guarantee's facilities. I think it is two years available.
Mar 07, 2011 | DeLonghi Caffe Nero BCO264 Espresso &...
I just got a eam 3500 machine. On first time instructions, no hot water would come out. produces a good cup of coffee though. When i've tried to froth milk for a latte, no milk is added to coffee. I have...
There is a blockage in the steam/ hot water circuit. By trying repeatedly to use these functions the steam boiler has now overheated and blown a thermal fuse ( thats why the alarm is displayed and now the infuser is in the wrong position for removal). If this machine is under warranty you should return it as soon as possible. If no warranty and you are a handy person (genuinely) then post again and i can help you fix it. No Good luck Rick.
Dec 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
We havn't had our Delonghi BCO-120T but for 3 months & the coffee side stopped working all together. My husband is a great handyman & after taking that side apart. the tubing & tank looks...
In uk delonghi spares by agents of kenwood.co.uk. there is a directory of local agents. before ordering element check thermal fuse attached to the element it may be open circuit.
Jul 29, 2010 | DeLonghi BCO120T Programmable Espresso /...
Need replacement thermal fuse for Shark steam mop Model:S3101W PART SEFUSE SF188E 192 DEG C 10A ET250V 00795 Joe Cook 502-839-6634
SE Fuse is a one time link. If it pops it must be replaced. Found them at Goodman thermal fuses for $1.25 ea. Not sure why it failed, unit is 6 yrs old, always used distilled water, never had a problem, it just quit. Circuit seems to be fine, will find out when part arrives.
Feb 12, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
It doesn't produce coffee after grinding. The first light on the bottom line is on.
I bought a pre-owned Delonghi Magnifica 4400 on eBay. It would grind the beans for an espresso, but then would not complete the function. Everything seemed to work fine except the machine would not deliver water anywhere-no espresso, no rinse, no steam, no hot water. I took it to the closest authorized repair shop (about 60 miles away) and it cost $260 for them to replace the "transmission system." I've had it back a few days now and everything is working perfectly...
Feb 01, 2010 | DeLonghi EAM3200 Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
137 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
