Question about Brother ES2000 Computerized Sewing Machine
Brother es200-how to remove back to get to bobbin winder
Took screws out of back to get to bobbin winder, back still will not come off
  • Brother Master
  • 627 Answers
New type of machines have hidden screws under handles, plugs, etc. Get them out. The other thing is snaps. Once the screws are out there are snaps. Be careful if you use something to pry with or you could scratch it.
Posted on Dec 17, 2014
How do I change the bobbin winder on the Brother ls2125 sewing machine please
In the meantime, you can pick up a stand-alone bobbin threader at the local fabric store or online. They cost ~$25. A lot of sewists prefer using the stand-alone because it saves wear & tear on their sewing machine and they can also wind bobbins without interfering with the machine's setup.
May 03, 2015 | Brother Sewing Machines
How do I fix my bobbin winder?
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Dec 01, 2014 | Sewing Machines
I would like to take the front or top off the sewing machine to see if the bobin winder is stuck.
There are several set in screws on back side of unit, remove all visible ones. making sure there are know covered by tape (refurbished do) then the o-ring gasket on bobbin winder is probably deterriated, replace and it should be spinning.
Oct 08, 2014 | Brother ES2000 Computerized Sewing Machine
How 2 fix Brother's CS-8060 bobbin auto winder to work?
Replacing the bobbin winder rubber ring.
  • The case halves are held together by 5 larger screws, one under the carry handle, obvious from the holes in the casing, plus one smaller screw up by the foot-raising lever.
  • There is also the final screw, which is a devil to find. You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
  • Once this tray is out you can see a small bar with a screw. Remove this screw and the 2 halves of the case will separate.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
  • Now you can carefully ease the ribbon-strip cable from the circuit board and move the case round to be able to access the screws that hold the circuit board. You do not need to pull out the other cables; just take a tad of care as you work.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
  • Take the opportunity to clear out any fluff and dust while you have the cases apart. Put ONE drop of oil in the center of the bobbin carrier rotating mechanism and one drop on any moving joints.
  • Replace the components/ ribbon cable in the reverse order, taking care not to drop the small screw! It is necessary to carefully line-up the hole into which it fits. It is surprising how easily the tray clips back into place, compared with the hassle you had getting it out.
I took both my CS 8080s apart last week to replace the drive rubbers. The first took nearly 1.5 hours, the next 1 hour as I knew what I was about.
Jun 17, 2014 | Brother CS-8060 Computerized Sewing...
Brother cs-80 winding bobbin makes whirring noise and doesn't wind
  • There is also the final screw, which is a devil to find. (see 3rd image)You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
  • Once this tray is out you can see a small bar with a screw. (see 2nd image)Remove this screw and the 2 halves of the case will separate.
I took both my CS 8080 apart last week to replace the drive rubber. It took nearly 1.5 hours along with the cleaning and lubing.
I am sorry the 3rd image is so small. It shows the screw to remove to access the arrowed screw in the second image
Feb 09, 2014 | Brother Sewing Machines
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
How to remove brother XL2230 sewing machine case
Take off the panel that conceals the lamp (see your instruction manual) and you will see another screw that needs to be removed before you can take the larger back panel off.
Jun 15, 2012 | Brother XL-2230 Mechanical Sewing Machine
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
Exterior Bobbin winder does not turn or wind a bobin? Model CS-8072
you will need to turn the speed to maxium then press the start button. I attached a site that has your manual and shows great pictures of how to wind a bobbin.
brother model CS-8072
Mar 15, 2011 | Brother Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
