Can you tell me the normal sound settings i.e equalizer, bass, treble, balance, volume
I changed the settings and i want to bring it back to factory settings
    Sniper:
  • 81 Answers
Usually there will be a "Reset to default settings" option.
Try it and see. All settings that you changed will be reverted back to original settings using this option.
Posted on Dec 13, 2014
I am suddenly unable to adjust the base, treble, volume, etc on my Alpine CDA-7940 stereo. Is there a lock or setting for this?
press the mode button, which is the audio knob repeatedly to choose the desired mode and rotate the knob until desired sound is obtained. as you press the mode button, the option will go from these followings: volume, bass, treble, balance, fade
Jan 13, 2015 | Alpine CDA-7940
Can you tell me the normal (factory) sound settings i.e equalizer, bass, treble, balancr, volume in videocaon 32" LCD tv
Do a factory reset to this TV. It will make all to factory settings.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Dec 13, 2014 | Televison & Video
42" LED42C45RQ need volume configuration
Hi Jennifer,
Settings of bass, treble and equalizer is a matter of personal choice. You can set them to your liking. Alternatively you can choose the sound mode ( like music, movie and theater ) of your choice. The balance setting off course must be in the middle or zero position so that both the speakers give equal amount of sound. In equalizer the extreme left column represents the low frequency sounds like the sound of drums. As you move rightwards the sounds go on becoming finer and finer and the extreme left column represents the fine sounds of the instruments like violin and sitar. Somewhere in the middle is there is human voice also. Play some music, try varying each column and see the effect. Good luck.
Jan 19, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
Hey! I have a problem with my sony MDR-RF81 headphones....when the bass is to loud...there volume is droping...when I listen to skirllex for example...the volume is high or low...but when the bass...
Hey there, the problem with your sony is not a hardware problem, the headphones are completely fine, its the amount of bass you are putting into the headphones, there are two solutions to this, if you're using a mobile device (Apple, android etc...), go to your app store and download an equaliser e.g poweramp, with this, you can adjust the sound going through to your headphones using the built in equalizer (usually 5-10 bands, research this if you have no knowledge of equalisers), you can use this to turn down the bass frequencies in the sound, or the only other thinkable options are if you are already have an equaliser in use, turn it down, because putting all of the bars to the top makes the sound horrible, research on some suggestions for equaliser presets (another word for equalizer settings), or just turn the volume down.
the reason this happens is because bass naturally overpowers treble, and if it is too loud, the treble and mids will be significantly quieter, headphones are a menace for this, so all you have to do is tweak the sound a little (using an equaliser) to find that perfect balance between the different elements of sound.:-) :-)
Hope this helped mate :-) :-)
Jan 10, 2013 | Sony MDR-RF810 wireless headset SONY
How to turn sound on phillips plasma 32 inch tv
Hello
I thinks that you want to tune your TVs sound parameters, and answers. As you know, when the TV is switched on it will display picture as well as sound, according to the volume level setting. If you want the qulality of sound much more better, by pressing Menu button and higlight the opton 'Sound'. As you select, there will be a 'tick' mark appears, indicating that sound option is selected. On to the right side, there will be Bass, Treble,and balance control displays. Use "Cursor Up" button to go box 'Bass", and increse or decrese Bass lavel as you likes. If you wants to adjust treble, use "Curser Right" button and do as previous to your taste. Come to the "Balance" option by using "Cursor Up or Dn' keys and set it to mid position. There will be indication for its mid position, and it should be in that position, so that you can hear sound from both speakers equally.
All jumpings and adjustments can be done with 'CursorUp, CurserDn, CursorLeft, CurserRight' Ok.
Oct 31, 2010 | Philips 32PT6441/37 32" TV
Alpine 9845 cde head unit car stereo i Cannot figure out how to access the Fader not the balance,altho i havent seen that function either. ive been to the alpine site and they dont even mention it. im sure...
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
Feb 11, 2010 | Alpine CDE-9845 CD Player
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
Adjust
I have an Alpine CDA-9813 and to access bass, treble, fade, and balance, you need to press the volume button. This button is usually rotated to adjust the volume but on mine, if you press it in, first time accesses bass, second press accesses treble, 3rd press accesses balance(left to right), and 4th press accesses fading (forward to rear. Press it a 5th time and it either brings you back to volume or back to the main screen. I think it is volume tho. I would assume that the 9853 would work very similar, if not the same.
Mar 21, 2009 | Alpine CDA-9853 CD Player
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
How to adjust treble and bass
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
Jun 11, 2008 | Clarion RDB325D
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
