Question about LG RHT599H Black DVD Recorder w/ Freeview Tuner 500 GB Hard Drive, 1080p Upscaling, HDMI
How do I dub onto a DVD-R in fast mode and get 8 x 30mins programmes instead of a solid 4hours in normal time
Everything I can think of and that works on the Toshiba RD-XV47KB. I can't dub on it and the instructions in the manual are useless. I've managed to work out how to put programmes into the folders but how the manual says doesn't work, so I'm not suprised that the dubbing doesn't either. I've had a couple of techies (their businesses) and they can't do it either. So can it dub like other recorders or not - am I wasting my time - should I just buy another but I'll never buy LG again if I can't resolve the dubbing issue.
the original program must be unedited - see response to
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: DVD Burning doesn't Disc in Setup..
Been checking out my m/c and found that there are many -r & -rw discs the m/c does not recognise which gives rise to this problem. However the m/c does recognise VERBATIM discs and I have been able to record and dub to them with no problems.
Posted on Mar 11, 2008
  • 6 Answers
SOURCE: How to record or dubbing from VCR To DVD
possibly because you are jewish
Posted on Mar 19, 2008
SOURCE: dubbing VHS to DVD
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
Posted on Feb 05, 2009
SOURCE: Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Posted on Jun 16, 2009
Recorded a movie on the DVR, played it & recorded it onto a Sony DVD-R with the Sony RDR-VX525, I believe it finalized & did everything it should. However, it won't play. It says disk error. I went...
what happened was that you probably chose a disc speed on the DVD that was too fast or slow for the dvd players that you are putting it in to. Try re recording it but when under the DVD section, on your remote, choose REC Mode till it says SP. That one should work on just about any dvd player. I had the same problem with mine. Here is a step by step instruction on how to dub from VHS to DVD correctly. If you follow all the steps, you should be fine :)
Jan 20, 2011 | Sony RDR-VX525 DVD Recorder/VCR
Unable to do anything!!!
In what state is the unit? Is everything else functioning asides from what you posted?
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
DVD Record wont finalize - LG RH397D
Have you changed brand of disks? Sometime different brands give different results.
Aug 08, 2009 | LG DR787T DVD Recorder
Dubbing from DVD to HDD
When you insert the dvd are you in dvd mode or hdd mode I think you have to be in hdd mode then go to settings insert dvd that you want to dub wait then it should become not greyed out, I had a similar problem when i tried to burn a dvd from hdd I had to be in hdd mode to dub I hope this helps let me know
Jan 23, 2009 | Philips DVDR3575H/37
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
I can record to the HDD on my LG HR902TA but I can't understand the instructions to get the copy onto a DVD to finialise and use in another DVD player. Thanks Angie
I found the info for this from a friend saying, instead of 'copy' I should see if anything related to 'Dubbing', by following the instructions for dubbing I was able to copy the programme onto a DVD then finalise it for watching in another DVD player elsewhere in the house.I thought if you dubbed something you over wrote the original sound.
Jun 30, 2008 | LG Televison & Video
HDD>DVD dubbing.....stopping, creating coasters
Still unable to find a solution for this problem. No response from JVC on their product either.
Jun 25, 2008 | JVC SR-DVM600
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVD problem
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
May 14, 2006 | Panasonic DMR-E85H DVD Recorder
LG RHT599H Black DVD Recorder w/ Freeview Tuner 500 GB Hard Drive, 1080p Upscaling, HDMI Logo
35 people viewed this question
Top LG Office Equipment & Supplies Experts
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
