Question about Refrigerators
My Samsung Refrigerator side by side door ,,Model,,SRS583DHD,, left hand side door ice maker increases temp and not producing ice,,;-(,,Bot
Bottom Half Of The Ice Maker Door Freezes up Ice on all the shelfs,,Stripped The Inside Of It Fully Defrosted The Fridge All the Lines Checked Fans ,,All Spinning Freely ,As We'll As Rear back of fridge fans & Lines In both sides of inner fridge ,,Are set the from screen ,,A Day Later same Thing,,;-(,,What Is The Best Way To reset ?,
    Novelist:
  • 187 Answers
Your description sounds like a loss of air flow problem. Check for overloading your freezer and fresh food side. In order for the freezer and fresh food side to work properly, the air vents need adequate room for air to circulate. I had a customer who completey filled the middle shelf with cardboard boxes and completely blocked air flow on the middle shelf The lower level near the evaporator was extremely cold and the upper area was room temperature in the freezer. Each shelf needs about an inch of room at the back and room between packaging to allow air to circulate.
Hope this helps
Posted on Dec 14, 2014
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
My ice maker stopped working
Test the ice maker cycle button on the bottom of the ice maker, if it cycles and fills, replace the ice maker because that is bad. If it cycles and doesn't fill, you could have a few waterline related issues. Check the water pressure out of the dispenser. If it's very slow Unplug the unit for 24 hours, increase the water pressure to the unit , get all of the moisture out and see if it fills after you plug it back in. I bet it's the ice maker though.
Jan 22, 2015 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
The ice maker is not working
There is a way of testing the ice maker.
Diagnostics for ice maker starts on page 27
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
We HAD A POWER SURGE NOW FRIDGE WILL NOT SWITCH ON
99% chance that the surge blew the power supply board. If it is a French door, bottom freezer model with ice and water through the left hand top door, it may have taken out the motherboard too. Samsung uses at least two boards, one main motherboard and a power supply board that powers the main.
Dec 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator RS2534WW ICE MAKER DOES NOT FUNCTION PROPERL
Hello here is how to fix the problem, first you have to remove the ice bin then then press the freeze temp and power cool buttons for about 12 seconds until the display panel switches to the option mode and you hear a beep.
A number under "Frige temp" corresponds to the option number. Press the fridge temp. button to increase the number and the power cool button to increase the number and the power cool button to decrease the number. set the option number to 3
now you have to select the input data to control the water supply time. Press the freeze temp button to increase the value. Press the power freeze bottom to decrease the value. Choose the right amount of water supplied to the ice tray which should be to where the water level is even with the rib on the inside of the tray.
input data = 00, 5 secs/01, 4 secs/02, 3 secs/ 03, 6 secs/ 04,7 secs/05,8secs
Let em know if this helps or not.
Nov 27, 2008 | Samsung RS2534 Side by Side Refrigerator
Have an LG LFX25960TT refrigerator with in door ice maker. The ice maker only makes 2 to 3 ice cubes at a time. (Too slow for my family's needs.) It appears like it doesn't get enough time to fill. Is...
Check to make sure the water supply to the refrig is good and the inlet screen where the water line connects to the refrig is clean. You can change the amount of water fill by pressing the button on the left side of the ice maker. (indicator lights above button show setting) Selecting "Ice Plus" on front of dispenser panel increases ice production for a 24 hour period. Ice maker should produce 6 cubes per cycle, aprox.. 100 to 130 cubes in 24 hours depending on freezer compartment temp, room temp, number of door openings, etc.
Sep 10, 2008 | LG Refrigerators
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
