Question about Life Fitness 9500 HR Crosstrainer Rear Drive
I changed the 6 volt battery when i connect the battery leads and used machine i press clear/pause button it will start again. I have to disconnect the battery to turn it off
  • Life Fitness Master
  • 914 Answers
If no key is pressed for 15 seconds, and the user stops pedaling, the console shuts down. You can also do the same when starting the machine, just step on the pedals to get them moving and the console should light up.
Posted on Jun 09, 2015
2000 BMW 5series, battery will not stay charged, and engine runs hot
it does not sound like a battery problem from the info provided. It sounds like your battery terminal post is not connecting at the battery. A cable may have a bad connector end on it and the car runs on the alternator once started. Buy a ten dollar volt/ohm meter and check the ohms resistance in the cables by removing the cables from the battery first and then connecting the test leads to the ends of each cable. The meter should read the same as if the leads we're connected to each other. To test the battery change the ohm meter setting to read volts DC in the 20 to 50 volt range and connect red to positive ( + ) side of battery and black lead to negative side ( - ) of battery. Battery must read more than 11 volts for most modern cars to engage the starter circuit, most working batteries will show more than twelve volts. Jump Start the vehicle with the battery connected and with the booster battery disconnected again test the voltage and it should read 14.5 to 15.5 volts. you may need to replace one or both cables or have the ends at the battery replaced. obviously the cables that run the starter are good or a booster battery would not work either. good bluck.
Jan 01, 2014 | Liquid Performance Premium Brake & Parts...
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
2011 Victory Cross Country starter hanging up
Hi, Bushmaster22 the word "SEEMS" does not exist in the Electronic Dictionary but it does exist in Q&A so it "seems" like you may have a bad battery or faulty charging system, now it is time to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type lead acid batteries must be topped off with distilled Holy Water and all batteries must offer their terminals to the battery charging altar to receive the Sacred Infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better. No matter how new the battery is, do not be lured into the false sense of "it's OK it has 12.5 volts" and not doing the test below, it could have little or zero "AMPERAGE" causing the battery to be faulty and must be replaced, AGM maintenance free batteries fall into this scenario more so than lead acid types.
Below is a quick and easy test to see if your battery is in good condition or needs Last Rites and must be replaced.
1. Make sure the bike is in "NEUTRAL"
2. Disconnect the spark plug cables.
3. Adjust voltmeter to DC volts 20-volt range
4. Place the voltmeter leads to the battery terminals.
5. Turn the run/off switch to run.
6. Turn the ignition switch on and press the starter button.
7. Watch the voltmeter as your engine turns over for 10 seconds.
8. If the voltage drops below 9.6 volts, the battery is faulty and must be replaced I "HIGHLY" recommend a maintenance free AGM battery they typically have more amperage for cranking.
9. Reconnect the spark plug cables if your battery is good and the bike starts ok, place the voltmeter leads on the battery and rev the engine to a steady 2500 RPM the voltmeter should read 14.5 volts DC anything in the 13's or less you have a charging issue that needs to be diagnosed and repaired.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Tell if Your Battery is Bad in 3 Easy Steps
Test Your Battery in 10 Seconds Reliable Load Test with Only Multimeter
2010 Cross Bikes pdf FREE
Motorcycle Service Parts Part Finder Victory Motorcycles Store
Victory 2011 Cross Roads Manual
Jul 05, 2017 | 2011 Victory Cross Country
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
How do I clear the memory on the player?
To clear the Memory of the Walkman Player, try formatting it with the Menu items.
The Steps to format the Player is, 1. Press and hold the BACK/HOME button in the pause mode until the Home Menu appears. 2. Press arrow keys to select "SETTINGS" and press the Playback/Pause button to confirm. 3. Press arrow keys to select "COMMON SETTINGS" and press the Playback/Pause button to confirm. 4. Press arrow keys to select "FORMAT" and press the Playback/Pause button to confirm. 5. Press Up/Down arrow keys to select "YES" and press the Playback/Pause button to confirm. "All Data will be deleted" Proceed? message appears on the display. 6. Again, press Up/Down arrow keys to select "YES" and press the Playback/Pause button to confirm. Now, Memory formatted message will be displayed.
I hope you find this information useful. Thanks,
Pradeep
Nov 18, 2010 | Sony Walkman NWZ-S616F MP3 Player
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
2000 Yamaha XJR 1300 starting problems
Hi, Nigel it saddens me to inform you that you have to put on your Battery Priest Robe and prepare yourself for the Ceremonial "LOAD TEST" but before you begin, maintenance type batteries must be topped off with distilled Holy Water and all batteries must present their terminals to the battery charging altar to receive the electrical infusion of Holy Ions until they have reached a 100% full charge of 12.5 volts or better.
1. Start by disconnecting the spark plug cables.
2. Adjust voltmeter to DC volts 20-volt range
3. Place the voltmeter leads to the battery terminals.
4. Turn the run/off switch to run.
5. Turn the ignition switch on and press the starter button.
6. Watch the voltmeter as your engine turns over for 15 seconds.
7. If the voltage drops below 9.5 volts, the battery is faulty and must be replaced.
2000 xjr 1300
Yamaha XJR1300 Owner Manual
OEM parts for Yamaha
Yamaha XJR1300 99 Service Manual
Oct 12, 2010 | 2000 Yamaha XJR 1300
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
Calculator will not come on
I have the same problem with the calc not responding to removing one batt and reinstalling while holding clear, etc. My fix is to hook up wires to the battery leads and plug the wire into a 120 volt outlet. Watch it light up, but do NOT breath the smoke as it is extremely toxic. ;-) lkw
Aug 25, 2006 | Texas Instruments TI-83 Plus Calculator
Life Fitness 9500 HR Crosstrainer Rear Drive Logo
380 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
