Question about Craftsman Garden
My craftsman snow thrower runs for about15 minutes before it requires more chock until it finally cannot run. Why is this happening
Cleaned gas tank, vent clean, new plug.
  • 26 Answers
First i would check engine compression. It will change once it gets hot and cause you to use more choke until finaly it wont run.and if that is okay i would rebuild the carburator. A rule i use in my shop is to always check compression first then go from there.
Posted on Dec 13, 2014
I need a service manual for snow thrower model# 247.888160
manual can be had at link below, if carb. is leaking fuel chances are it has dirt in it and requires rebuilding which I will post a second link to.
press the helpful button
Craftsman 247 888160 Owner Manual
How to Fix Snow Blower Carburetor
Oct 15, 2015 | Craftsman Sears Snow Thrower Manual Model...
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
Runs for 10 minutes and stops
When running is the idle smooth or up and down?
Is the chock operating, or adjusted after the motor gets warm?
Is the carburetor needle adjusted after the engine idles to warm as it should be to be set correctly.
Are you blowing snow when it dies or at idle?
Feb 01, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Nov 20, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
I have a Tecumseh 4.5 2 cycle engine on my snow
fuel filter thats were i would check fuel will turn gummy in the filter if it sets
Feb 10, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Snow thrower Ariens engine tecumseh 9.5hpr.engine pulses high and low for about 5 minutes and stops.Start it again and same thing happens,any suggestions? Thanx
Try draining all the old fuel out of the fuel system. Fill the tank backup but add a little "seafoam" gas additive to help clean out the system while running.
Dec 30, 2009 | Garden
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
