Question about Haier HLP23E Top Load Washer
Haier HLP23E - When I press start, the water flows in and out at the same time.
The water does not stay in the machine. Rather, it flows right out of the drain hose. This goes on for awhile, then E4 message comes on. HELP!
  • 102 Answers
Hi Lina, accordin to the Haier website, E4 stands for "water inlet problem. Water can not inlet or cannot reach the selected level in a proper time.". Unless the ingoing water pressure is really low, I think you need to service the machine. Anyway, hope this helps!
Posted on Dec 13, 2014
Why does my washer only drain when the hose is at ground level? It also seems to be filling with more water than usual - almost overflowing for a small load of laundry.
the water pump on a washing machine is nothing more that a water stirrer as the vanes are straight out
the pump is full all the time and passes water if the hose is laid on the floor. the fact that it is not pumping indicates that it is not getting power at the right time. or the motor of the pump has malfunctioned O new pump) The over flowing machine indicates that the hose to the pressure switch ( what you turn for the water amount ) is blocked or has a hole in it
With both problems combined it may be a faulty control board so have a washer machine mechanic have a look at it.
May 10, 2015 | Haier HLP23E Top Load Washer
LX30H THROWS A CODE EO after running awhile. I hit the high reset button under the flaps on the front for both the boost and reg elements . It will work for a couple cycles and then does the same thing....
Machine won't fill or won't fill high enough. site water pressure meets minimum flow pressures. (LX18, LX30 display shows working.
"E0," "E2," "E3," or "E4". LX40 display shows "DR1 PRBLM," "FILL1 PRBLM," FILL2 PRBLM," or "FILL3 PRBLM". Machine will not run.)
1. Low water pressure - check for clogged hose strainer; check that
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be
4. Drain valve open - turn machine OFF to drain machine, then
ON. Repeat twice (this assists in clearing any drain valve
obstructions). Wait for machine to reach READY mode and
press WASH. Slowly open door several seconds later and note
water level. Close door; 30 seconds later, open door slowly and
check that water level is the same as it was. If not, repeat the
OFF-ON procedure. If problem persists, call your local Hobart
Service Office.
5. Delime machine.
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F18615%20Rev%20I.PDF
Dec 10, 2013 | Hobart Lx30h Commercial Dishwasher
Keep getting a E4 Code
This E4 Phenomena means "no water":
No or slow water fill (not
reaching the full level in 15 min),
therby computer sends display message "E4"
Reasons:
1) The house water tap is not open, or
2) This is the most common E4 reason- The water inlet valve (that the hose is connected to) is blocked.
3) The water pressure is too low and the flow is too weak.
Solutions;
1) Open the water tap, then push the START/PAUSE button again.
2) Clean the water inlet valve. Shut off house water supply on the wall then, unscrew (lefty loosy) each hose from the house and the machine and look for a screen and clean the junk away from the screens. You may have 1 or 2 screens depending on the hose there may be 1 screen where the hose connects to the house and another screen inside the machine valve. Then, return hoses and turn on the water pressure again, Then push the START/PAUSE button again.
3) Wait for the normal water pressure to return to the house before use.
Oct 08, 2013 | Haier HLP23E Top Load Washer
Leaking water from the hose connections
Had the same problem w/the water inlet w/initial installation. When the water inlet was hooked to the faucet and into the washer, water leaked on the washer end. The manual tells you to put a new "flat" washer (provided) in the washer machine water inlet, but water still leaked. It's actually the not flat washer, it's more of an "U" shape washer that goes into the washer machine water inlet and fits right over the filter in the water inlet valve. Leak was solved, but faucet was on and water was not filling in the drum. Turn power on, select cycle, water level, and press start and water should start filling the drum.
Jul 28, 2013 | Haier HLP23E Top Load Washer
I have Beco WM616 7W washing machine...when I start washing...water should filled in washing machine but it comes out from somewere..all programms working...just water comes from bottom..
Check all your hose connections. Sounds as if the drain hose has come loose or burst. (common fault in all machines).
Open soap drawer, and check that water is flowing into it.
If no water is flowing into it, looks like the water connection hose at rear is not secure.
If water is flowing into the drawer, but not staying in the drum, then check the drainage outlet hose is secure and undamaged.
Jan 21, 2013 | Washing Machines
WATER GOES INTO MY WASHER AND RUNS RIGHT OUT
tub rubber is torn or cracked can be replaced but for cost u might buy a new washer
Nov 18, 2012 | Haier HLP23E Top Load Washer
Haier HLP23E Top Load Washer Logo
406 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
