Question about Maytag Refrigerators
Cannot get ice & water filter out in order to install new one. Following directions, seems to be stuck.
Directions to turn counter clockwise . Will not release
    Novelist:
  • 187 Answers
Try this. Shut off the water supply, and try to dispense water. This will eliminate water pressure on the filter and allow easier removal. With water pressure in place, you are having to try to overcome water pressure and requires a lot more effort.
If this does not work you may need to find out if your refrigerator manufacturer has a special wrench to help removal of filter.
Hope this helps.
Posted on Dec 14, 2014
We have a igloo counter top ice maker the ice has a metal taste to it.
Taste is generally associated with the water entering the freezer chamber. You should have a FILTER in line with the ice maker to avoid the problem.
Jan 14, 2018 | Refrigerators
How do I change water filter
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I am going to have to tell you where the water filter might be.
1.) On the lower, front bottom grill or toe plate, in the center there is a round hole. In this hole is your water filter. Grab the end of the cylinder and turn 1/4 turn counter clock wise and pull out. There will be some water in the filter. Slide the end cap off the old filter and slide it back on the new filter. Insert the new filter, push in and turn 1/4 turn clockwise.
2.) In the upper back right hand corner of your refrigerator section is where your water filter is located. There is a plastic cover plate around it, but you can still see the bottom of the filter canister. Reach in and turn the bottom of the filter 1/4 turn counter clockwise and remove. Insert the new water filter and turn 1/4 turn clockwise.
After installing a new filter, there is air in the filter. Run your water dispenser until a steady flow of water come out. You will get air & water spurting out.
If you only have a ice maker, you will have to manually cycle your ice maker until it fills.
The water filter change light is not tied into anything in your unit. It is like a egg timer. Even when the indicator light indicates to change you water filter, you only change your water filter when either the water coming out of the water dispenser is slow or you are getting small ice cubes.
Nov 23, 2014 | Kenmore Refrigerators
How to change out the filter
Push in turn counter clockwise pull out filter it may seem stuck but it will come out you should find it inside fridge.
Aug 31, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
I CANNOT REMOVE THE DASHER TO DISASSEMBLE FOR CLEANING. THE MANUAL FOR THIS SUNBEAM ICE SHAVER SAYS TO TURN THE DASHER COUNTER CLOCKWISE UNTIL IT UNSCREWS. FROM THE UPPER HOUSING. NO WAY IT JUST KEEPS...
Laura at ifixit posted a response 4 days ago that helped me solve this problem. ifixit(dot)com/Wiki/Sunbeam_Snow_Cone_Maker_Troubleshooting
I was unable to remove that dasher following the directions. When I turned the dasher counter clockwise it just spun and spun the motor. To fix this I removed the four screws at the bottom of the machine (hidden under gray rubber foot pieces) Removed the white base and held the clear circle motor wheel steady while rotating the dasher counter clockwise -it released in just a few spins. After reassembling the product the dasher removes per manufactures directions.
Hope others can get there machine fixed. I called Rival with this fix as well in hopes others could clean their machine. Thanks again to Laura at ifixit.com!
Aug 10, 2013 | Sunbeam Slushies Snow Cone Maker Snowcone...
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
How to change the filter?
If it is the standard whirlpool, you find the filter on the bottom, sticking through the front kickplate. You grabb the knob and turn it counter clockwise, a quarter turn and then pull out. Install the new one in exactly the reverse order that you removed the old one. There is another model that has a button to the left of the filter that you have to press in and then the filter pulls out. Good Luck, Appliance Specialists
Dec 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Filter replacement
Hi and welcome FixYa. I am Kelly.
I have to assume we are talking about a refrigerator. The question listing is under blenders and if so that is one fancy blender.
On most refrigerators the filter is in the lower left side of the floor grill. The will be lable that says press to release. Then you turn the filter cap counter clock wise to unlock the filter. When installing the new filter you must swap the cap from the old filter to the new one then press in hard and turn Clockwise until it locks in place. (see the instruction sheet with the new filter)
Thanks for using FixYa,
Kelly
Apr 24, 2010 | Blenders
Have an LG american type fridge freezer and need to change the water filter for the first time and don't know how to
Good day,
Grasp the filter firmly and turn it counter-clockwise until it releases.
Some water will spill so hold a small bowl under it.
Install the new one in reverse order. Pushed up turn clockwise until it seats.
It will take a while to purge the air out of the system, so be patient.
Jan 31, 2010 | Refrigerators
Water filter replacement
Fm, it's not threaded, turn it counter clockwise until it stops (should hear a click), then pull it out. Push the new one in all the way and turn it clockwise, you should hear it snap in. You may have to use a little force. If you are still having trouble, give them a call at 1-877-714-7481. Catriver.
Jun 28, 2007 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
90 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
