Water is entering the machine but going out the drain pipe immediately
Not much
  • Washing Mach... Master
  • 3,382 Answers
Most washers come with a hose that has a 180 degree bend, this is for hooking over the drain pipe which is about as high as the washer or a little bit higher. There is no valve in the drain, when the pump engages it puts a bit of pressure on the drain water forcing it up the drain tube into the drain. From your description you drain is to close to the ground, raise it and your problem will go awah.
Posted on Dec 13, 2014
    Problem Solver:
  • 5 Answers
Drain pipe too low there I usually a mark line on back of washer
Hi,my machine skips putting in water and goes to drain cycle immediately. So no water goes into the machine
does the water get to a certain level but keeps filling while draining down your stand pipe. if so the end of your drain hose os pushed to far down the stand pipe and is syphoning out. a bit common. pull the end o the hose up closer to the opening.
Jun 14, 2017 | Washing Machines
Water drain out immediately while filling the washing machine
you should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Feb 10, 2014 | Simpson Esprit 750 Top Load 7.5kg
Hi, I have whirlpool SM 8525147-A washing machine. The problem is that when I try to wash the clothes the water enters the machine and immediately drains out.
is there a stand pipe for the drain . at least as tall as the machine behind it close to the wall. if not then that is the problem . if the is it might need an addition of a siphon break .
Sep 09, 2011 | Whirlpool Washing Machines
It won't hold water--it just runs through it
Make sure the drain pipe is at least 30 inches higher than the base of the washer, that the drain hose going into it is not sealed where it enters the drain pipe, and that the drain hose is not shoved down into the drain pipe so far that it is in the water level of the trap.
Mar 06, 2011 | Whirlpool LSR6332K Top Load Washer
When the water is entering the tub it immediately goes out the outflow. The tub will not even fill up a little bit. What could be the problem? thanks
The drain hose outlet must be located higher that any expected water level in the tub. If too low, gravity drains the tub as it is filled. Extend the (a) drain pipe up to the proper level, even if you are using a floor drain to carry away the water. Hope this helps!
Jan 27, 2011 | GE WDSR2080D Top Load Washer
My sister just brought me an old washer and for the life of me i can't figure out why it won't keep the water in. it pumps in water, but it immediately drains it. i'm almost positive it is set up right....
i suspect you have it wrongly installed on the drain.
if the drain pipe goes into a standpipe, you may have drain pipe pushed too far down and a syphon forms. drain pipe need only go into standpipe a few inches.
otherwise, if not drained into a standpipe, take drain hose up in a swan neck to worktop level
Sep 10, 2008 | Whirlpool Washing Machines
Machine filling and then immediately draining
Hi You need to higher your outlet pipe on the back of the machine there is usually a clip to hold the pipe in place 3/4 of the way up the machine so it looks like a u upside down its should stop the machine from emptying straight away
Apr 29, 2008 | Zanussi ZWF1430W Front Load Washer
Kenmore 80 Series washer
your stand pipe is to low raise it up above the machine alittle bit
Mar 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washer won't fill up
The problem is most likely your drain. If there is no air break at the drain,( a gap where the hose goes into the pipe so air can enter) Your water will siphon out of the machine. Also make sure your drain pipe is higher than the tub of your washer and you only want about 6 inches of the drain hose sticking into the pipe. If you have water coming back out of the pipe when the machine drains, you will need a plumber to clean the pipes or replumb the drain. New washers pump out faster than older ones did and they need a good drain to handle the flow.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
