Question about Westinghouse Refrigerators
FIX WATER DISPENSER
The water dispenser broke inside, don't know how to get panel off
  • Westinghouse Master
  • 744 Answers
Hello Rodney;
My name is Peter. I am a retired field service refrigeration technician.
Well, you did not provide a model number, so I have to speak in general.
On some units there are two slots on the bottom of the frame for a screw driver to pop the bottom out. There after you must push the frame side inward to release the plastic tabs. Be careful it is easy to break these tabs.
You can go into the following website, put in your model number and get a diagram of your dispenser.
Water Filters Lawn Garden Appliance Parts
Posted on Dec 14, 2014
How do I repair a samsung french door refrigerator rf 265,266 with interior water dispenser that parts fell into cabinet?
The parts are readily available for your repair, however, you should contact a qualified Samsung technician. If the dispenser is not assembled correctly, the water flow may not shut off. The resulting water damage could be very expensive compared to a service bill of $150.
May 01, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Fridgidaire refrigerater dispenses water
The part number you are going to need is 241734302. This is the water valve located in the back of the machine. Whats going on is the solenoid for the dispenser isn't seating properly and when the icemaker calls for water the pressure is enough to push through and come out the door as well
May 24, 2012 | Refrigerators
Water dispenser stopped working. Water valve works
A major problem with the ge side by side refrigerators with metal liners is water freeze-up inside the door of the freezer. Short term repair is to heat the dispenser area CAREFULLY with a hair dryer right at the point where the water spout comes out.
The long term fix involves installing a heater in the dispenser part number wr49x10173 @$60. The kit comes with installation instructions..
Let me know if you have any questions!!
Aug 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser is not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 05, 2009 | Refrigerators
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
The crazy water dispenser
Yes IF you turn off the ice make it should stop the water from coming out of the water dispenser.
If can you strip and splice a wire you can install a new diode....
1) unplug the refrigerator
2) Remove the back cardboard cover
3) Find the water valve at the right side. wires that go to the water valve you will is a diode
4) cut and splice in the new diode...
Let me know if you do it ,,,
Nov 03, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
