Question about Sony Xperia Tipo Dual ST21i2 Black Android 4.0.3 Dual SIM unlocked phone
There is a sensor problem in my sony xperia st21i
I just change only speaker and after 30 min. i got sensor problem automatically
    Master:
  • Sony Master
  • 752 Answers
Perform a soft reset, this should resolve the problem. the button is located behind the micro sd card slot cover, small red, you can't miss it. search on line regarding Xperia soft reset instructions, pretty simple and fast. you won't loose any data.
Posted on Dec 14, 2014
2002 hyundai sonata lx will not shift gears automatically but will manually
Huyndai's are netorious for transmissions doing funny things if the Throttle Possition Sensor is bad. Not an expensive part that you could probably change yourself. It is an inexpensive try, if it does not remedy the situation. Also, the computers regulate shift patterns. You might unhook the battery and leave it unhooked for 30 min. or so, and see if it will re-learn shift points.
Feb 27, 2015 | Hyundai Motor 2002 Sonata
AUTOMATIC HEAT SETTINGS NOT WORKING PROPERLY
lg's have a dry sensor that senses the wetness of the load they are not that reliable.. and will shut down the machine does it work on manual timer? meaning set it on high for 30 minutes.. it will probably run the 30 minutes... I have had this issue with my lg and so I just use the manual settings cheaper than having a 300$ service call. Its a problem with the dry sensor on the lining of the drum...
Dec 09, 2013 | LG DLE5977 Electric Dryer
Buttons don't make any sound but can hear dial tone, speaker phone doesn't work, phone dies fairly quickly - would this all be caused by bad battery and what is the life of battery in a Panasonic cordless...
First off, try changeing from tone dial to pulse dial and try calling out. If that does'nt work, touch bad is probly bad. As far as the speaker phone it does not work off battery's it works from the main base which is powered from the A/C. And for the battery life, when you have a cordless phone you have to build the life to the battery, what I mean is : first time you charge it for 12-14 hours, after that use the phone and do not put it back into cradle, the battery will hold a charge for 8 hrs, if you use it for 30 mins and put back on cradle untill next use, use another 30 min and continue doing this the battery will build its life to 30 min and always die after 30 min, try to get into leaveing off cradle all day and charge while you sleep and keep off cradle all day.
Nov 07, 2013 | Panasonic Lands Phones
BMW 2003 325. When I derive a car for about 30 min
Is this the oil pressure sensor you changed?
Aug 31, 2013 | 2003 BMW 325
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Speaker doesn't work
Your speaker is damaged, hence it is not working.
You have to change the speaker.
Jun 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Hello, my speakers hum for 10 to 30 seconds when i turn on my receiver. sometimes they do this even with sound coming from the system for up to 10 min. i tried changing the speakers. moving the power,...
i think ur unit deposits humidity . . try to clean it up with smooth paint brush over the boards and connectors . . better yet spray some contact cleaners i think this will do . . . otherwise resolder is needed . .
Feb 23, 2010 | Onkyo TX-SR304 Receiver
Sound Shut Off
i understood your problem...u cannt hear sound after listening for 30 min continuosly..so best way is listen songs for 28 min and shut down ur computer and again turn it on...thus can listen for 28 min more..do this as long as u wish to listen songs..
do remember,,,no gains,,no pains...
Jan 07, 2008 | Logitech X-540 Computer Speakers
Sony Xperia Tipo Dual ST21i2 Black Android 4.0.3 Dual SIM unlocked phone Logo
104 people viewed this question
Top Sony Cell Phones Experts
M_Butkus
john h
Eric Sutherland
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
