Dark screen on my wd60735 Mitsubishi big screen TV but here sound very good what the problem?
  • 102 Answers
Hi Jomo, sounds like your TV lamp is not working and needs replacement. You can buy the replacement online as well. It's quite popular. Good luck!
Posted on Dec 13, 2014
  • 668 Answers
SOURCE: how do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Posted on Jun 29, 2009
  • 109 Answers
SOURCE: 52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Posted on Mar 29, 2009
  • 1153 Answers
SOURCE: 50" MITSUBISHI BIG SCREEN (MODEL#VS-5076,
INITIALIZE THE SYSTEM CONTROL. WITH THE REMOTE CONTROL PRESS "MENU 2, 3, 5, 8, " USE THE ADJUST BUTTON TO SELECT "INITIAL" AND PRESS "ENTER"
Posted on Mar 17, 2008
  • 1153 Answers
SOURCE: Mitsubishi big screen tv
Do the self test first find the error code. Look on here or ctechnicians.com
Posted on Jan 03, 2008
Adolph
  • 137 Answers
SOURCE: Big Screen TV not working
Check your video input cable or replace, maybe it is damage if not Video chip problem etc
Posted on Dec 24, 2007
Mitsubishi WD60735. Had white spots. Later lamp went. Replaced DLP Chip and lamp. Screen lights up very slightly. No sound. Green LED light is steady. Projection lamp is on. What is my problem.
Check and replace the lamp inverter too. Lamp replacement should always accompanied by the inverter too. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Mitsubishi WD60735
How can you clean the inside the screen of a tv WD60735
You can use compressed air but it will leave the dust inside. If you remove the bezel you can take the front face off and clean it that way. I would not recommend using cleaning solvents to clean the screen use a dry cloth. The screws are on the back side along the edge of screen.
Oct 18, 2015 | eReplacements E-replacements 915b403001-er...
I can't get any sound out of my TV. I have everything set up as it should be. BUT The volume does not work at all.
That set, like many RPTV, may have an audio setting in the menu area for internal or external audio. Make sure it is set for internal (unless you are using external amp/speakers). Good Luck.
Aug 15, 2014 | Mitsubishi WD60735
Replaces the DLP Chip and the Volor Wheel on a Mitsubishi WD60735 and I get no power and a blinking "Lamp Light"...
Count the number of blinks...it is displaying the error code.
The number of blinks will repeat several times...count them.
Then contact Mitsubishi Tech support, they will tell you what the code means. For example, if the TV blinks 4, then 3 several times. The code is 43. Good Luck
Nov 13, 2013 | Televison & Video
I have a mitsubishi model wd60735 how do I get to the lamp
If you removed the plate beneath the screen on front a door should be there or it is possible it is one with the door on back--clearly marked.
Apr 05, 2012 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi dlp tv model wd60735 the picture is not bright any longer any suggestions
I think you have one of the models that have two mirrors inside: not Mitsubishi's best idea.
Most have just the large mirror in the back but I think this model has a very small mirror at the bottom (odd shape about 4x6 inches) behind the front screen which faces upwards and gets dirty from the fans inside the set.
It is amazing how much it can dim the picture; Caution, if yours has it the only way to get at it is to remove the entire front screen assembly---a phone call to Mitsubishi will confirm if your model has the two mirrors----the big one never needs cleaning(almost never and is special).
If you find your model has two mirrors either consider having a pro come out and do it (15 min job) or You Tube it to see if instructions there.
look before you leap as this is usually a two person job.
If you have questions let me know.
I have seen this before in these sets
SD TECH
May 14, 2011 | Mitsubishi Televison & Video
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mar 17, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
