Question about Samsung Washing Machines
I have a Samsung Bigwash B1113J washing machine. The detergent tray is stuck, will not open. How do I open it?
The detergent and recess tray is stuck. Will not open. How do I fix it and get it opened?
  • 102 Answers
Hi Esther, have you recently removed the drawer to clean and put it back in? Does the display show any specific error (that would be something like E+a number)?
Posted on Dec 13, 2014
Testimonial: "No, it is a possiblilty something inside the tray was sticking up , I am not sure. Now it will not open. I try to pull it out . It comes out maybe a cm or two then stops."
Water backing up in detergent trays Samsung vrt Steam front loader
In some machines, the detergent tray is flushed to empty completely.
Feb 02, 2017 | Samsung Washing Machines
Detergent dispenser is stuck and cannot open on LG Tromm washing machine
There is a small tab that one has to press down to unlock the retainer clip.
Press this down while pulling the tray outward.
Aug 06, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Cannot open Samsung bigwash door. Power trips when switched on, so cannot open electronically. Cannot find override.
I need mdl. # to search it out. In the meantime, look thru your manual if it's gone try unplugging it for a minute and letting it reboot.
Feb 16, 2013 | Washing Machines
I have a Samsung Silver Care front loader washing machine. When I turn it on water comes out the detergent dispenser drawer and a little oozes out of the main front door. Any ideas? Thanks, Kelly
Remove the dispensing tray (look for an under side spring clip or release) and check the fluid exit point--the machine washes the detergent into the drum along with other washing compounds. You may be better off using a liquid detergent rather than a powder. This may also fix the main door leakage too. Hope this helps!
Aug 15, 2010 | Samsung WF328AA Front Load Washer
Samsung washer b1113j 24'' front load problem is the debris filter won't pull out when un screwed to clean & upon trying now water leaks badly when i screw it back in purchased yesterday used ?
I have the model number b1113j and the stainless steel drm on the inside is off is there any manual that can show me how to take the machine apart there is no warranty left and I am not payi g the cost to get it fixed
May 08, 2010 | Samsung Washing Machines
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Detergent dispenser stuck
Had the same problem here today, the softener dispenser blue plastic piece was loose jamming the whole dispenser tray, to resolve remove top cover, two screws on top rear, slide the cover towards the back, you will then see the detergent dispenser, press the right clips and pull it off slightly at the back; do not put too much pressure and try to remove the cover completely, just pry the plastic cover a bit then pull the detergent tray it should come right out.
Apr 07, 2009 | LG WM-3677HW Front Load Washer / Dryer
Samsung bigwash washing machine b1415j
on the front of the machine at the bottom is a panel you can take off to clean the filter. take this off and there is a plastic cord you pull to release the door! hey presto
Oct 23, 2008 | Washing Machines
Maytag front load washer mah8700a power dead clothes stuck inside!!
take out he screws that are under the detergent tray door and remove the whole detergent tray assembly, there should be a plastic chord with a loop on the end; pull it hard to unlatch the door.
Jun 27, 2008 | Washing Machines
Washing Machines Logo
159 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
