When we plug in the chord an press power the tv come on an the goes off back
  • 1,915 Answers
Probably a bad power supply in the TV set. Further diagnostics would likley require disassembling the set.
Posted on Dec 13, 2014
The print cartridge can not move
turn on the printer then try to move it manually..
if it does not work turn it off and try to move the carrriage manually.
still does not work then do following steps...
1) connect printer directly to wall
2) remove the power chord from back of the printer and then press and hold down power button for 30 sec. release the button and plug in the power chord..
3) if still it does not work out then unplug the power chord from the back of the printer.. press and hold the pound(#) and number 6 key together. then without releasing the button plug in the power chord.. once the power chord is plugged in release the buttons.. the printer would align .. if still it does not work then replace the product as it is an issue with the carriage
Mar 26, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 6310 makes loud grinding noise on right side
1) connect the printer directly to wall
2) try different wall outlets
3) unplug the power chord and then press and hold down the power button for 30 sec. release the button.. then plug in the power chord
4) then try to move the carriage manually from left to right.
5) check if any papers or any thing is stuck inside the printer or not..
6) then unplug the power chord.. press and hold the pound(#) and no 6 key together and then without releasing the button plug in the power chord..once the power button in plugged in release the button..
the printer would go back to factory defaults..
check what happens
7) issue not resolved the service the product..
Mar 26, 2011 | Office Equipment & Supplies
Hi, I have a hp psc 2410xi photosmart and I can't get read of the eroor message remove and check your ink cartridge. Please help
2) try with different walloutlets
3) remove the cartridge and the clean the copper contacts with a lint free cloth
4) then unplug the power from the back of the printer and then press and hold the power button for 30 sec then release the button.plug in the power chord.
5) then unplug the power chord from the back of the printer.. press and hold down the (#) pound and 6 key together and then without releasing the button plug in the power chord.. once power chord is plugged in release the two buttons..
then check what happens.
6) try replacing ink cartridges
7) if it does not work service the product
C309a ink level shows low after replacing cartridge with cosco refilled original HP cartridges???
1) remove all the orange tape from the cartridge properly...
2) plug in the power chord directly to the walloutlet
3) unplug the power chord from the back of the printer.. then press and hold down the power button for 30 sec... then release the button.. the plug in the power chord and turn on the printer..
check the ink level...
4) if it does not work press the setup button on the printer >>> press the right arrow and go to Tools >>> clean printhead...
5) after it is done again press setup >>> Tools >>> Align Printer.
after that is done check the ink level again...
if it still does not work follow the next step..
6) unplug the power chord from the back of the printer.. then press and hold the pound(#) and 6 key together.. then withough releasing the button plug in the power chord... after you plug in the power chord release both the buttons... alignment will continue... do not stop the alignment...
after it is done again check the ink level...
7) you can also check the ink level by pressing the setup button >>> Tools >> Display Estimated Ink Levels...
Hope this works for you...
Jan 25, 2011 | HP Photosmart Premium C309A All-In-One...
Fax problem
first try to make a copy and check if you get the same error message..
if you get the same error message..try these steps..
1)connect the printer directly to the wall outlet..and try to make a copy..if you get the same error message..then go the next step
2)unplug the power chord from the back of the printer..press and hold OK and CANCEL buttons together..
3)while pressing these two buttons plug in the power chord to the back of the printer..after you plug in the power chord do not release the buttons untill the screen goes blank..
4)once the screen is blank release the buttons and turn ON the printer..
5)wait for the printer to complete the initialization..
6)then try to make a copy and check if it is copying successfully..
if not machine should be replaced because scanner bulb is not getting enough power or scanner bulb is gone bad..
please try these steps and let me if the solution has worked
Mar 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 6310 makes a squealing noise when printing, like the roller needs oiling-any suggestions on what to do?
turn off the printer..connect the printer to wall outlet..and try to make a copy..if its still the same..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold OK and CANCEL button together..
4)after you plug in the power chord do not release those two buttons..
5)keep pressing those two buttons till the screen goes blank..
6)once the screen is blank release the buttons and turn on the printer..
7)wait for the printer to get initialize..
8)once the initialization is complete..try to make a copy..if the printer is still making noises..then machine should be replaced..
let me know after you perform these steps
Mar 10, 2009 | HP Officejet 6310 All-In-One InkJet...
Reset power when it 's plug in
as you are getting the error RESET POWER..
turn off the printer..unplug the power chord..connect the printer directly to the wall outlet..and then turn on the printer..if you are still getting the same error message..perform these steps..
2)press and hold the ON button..while pressing the ON button plug in the power chord to the back of the printer..
3)after you plug in the power chord do not release the ON button for 30seconds..
4)after 30seconds if the printer is off, go ahead and turn on the printer..
the solution should resolve the issue..if its still the same please get back would give you some more steps..
Mar 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Power cord came out the back of the tv
1. Replace the power chord.
WARNING HIGH VOLTAGE: Do not attempt to work on your set without another person present who is trained in CPR
If the power chord is a plug in type , plug it back in.
if the power chord was ripped out , you need to repair it.
if the power chord was broken before you discovered it, you will also need to repair it.
I do mean a proper repair not just an electrical tape job.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division.
Sep 24, 2008 | Televison & Video
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
