We can not get the poilet light to light what would be the caus
  • 5,649 Answers
This could be the thermocouple needs replacing!
Posted on Dec 13, 2014
I have a Coleman Natual gas forced air Model 7970C856 The poilet light stays on but furance burner does not kick on. What could it be?
Hello, this could be a problem with the thermocouple or gas valve. Start by replacing the thermocouple since it is very inexpensive, if that does not get it going sounds like the gas valve will need to be replaced
Oct 04, 2011 | Coleman Propane Forced Air Heater...
Carb settings kx 250 '02. 2 stroke. poilet screw
Screw this screw in until it stops, then back out 2 1/2 turns this is your starting point to try and adjust to run.
Sep 06, 2011 | kawasaki KX 250 Motorcycles
I Have a rinnai 26 has been working for 3-5 years now, just stoped. looks like the poilet light is out, can any body lend a hand
Firstly this unit has no pilot light, it lights automatically when you turn a tap on. Many reasons for it not working. If it just sits and does nothing when you turn a tap on you need to start with the flow turbine or a electronics fault on the PCB. Really recommend getting an expert in, too many things on these that can cause this fault. Sorry to be blunt.
Nov 27, 2010 | Rinnai Digital Remote Water Heater Control...
POILET LIGHT WILL NOT STAY LIT
tip of thermocouple not touching the flame enough..or need to replace entire pilot assemble chk front of w/h for 800 number for warranty info..
Nov 25, 2010 | Rheem 36" Water Heater Thermocouple Kit
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Nov 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have dean fryer model sr42 my problem is pilot working properly but burnners not working gass comming to poilet but not to burnners
Just cleaned it ,huh? If it will light with a match, Lite them all and let them burn to dry out.If that doesn't work ley me know.
Oct 31, 2009 | Kitchen Appliances - Others
Need help with problem
Once you lit the furnace did you turn the valve to the on position. Russ
Jul 20, 2009 | Coleman Propane Forced Air Heater...
PILOT LIGHT WILL NOT LIGHT
the thermocouple not only keeps the pilot on but lets the gas valve know its okay to open on a call for heat, remove your thermocouple and clean it with a fine grit sandpaper and if this doesn't work replace it all together.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
When i turn on the poilet it turn on the frier it reach to temp then turn of every thing
If the main burners ignite with the thermostat off, you could have a bad t-stat or a bad gas valve. If the gas valve is a combination safety, (all built into one), check your wiring connections.
If I have the symptom right, you should call a professional.
Mar 02, 2008 | Imperial IFS40 Deep Fryer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
