Question about Ovens
My fan oven is not heating up yet the grill works and the fans going around?
  • 3,368 Answers
Check the bottom heating element. If you give us more information we may be able to give you a better answer.
Posted on Dec 13, 2014
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
barkencoa
  • 3463 Answers
SOURCE: fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Posted on Aug 24, 2009
Testimonial: "Possibly looking for a bit more info. My manual talks about top and bottom elements. I take it the grill is the top element."
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
The fan works but no heat. Grill work
You need a new oven element. The oven element is not visible inside the oven as it is located around the fan, behind a safety panel. Its a simple DIY job if you are handy. Isolate oven from power. Look inside oven to rear panel where fan is located and there should be 4 screws holding the safety panel in place to cover the fan, Remove cover and you should be able to see the element which will probably be circular and mounted around the fan. Remove the element and take with you to ensure a correct replacement at your parts dealer.
Jul 03, 2015 | Ovens
My omega europa oven is not heating up .grill fan
Mar 18, 2010 | Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Fan but no heat
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
Smeg SNZ91MFX1 Fan heating not working
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
48 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
