Question about badoo Meet New People on Badoo
THIS SAME RESULT I WANT TO SIGN UP - badoo Meet New People on Badoo
How to put in an =sign in the calculator? Is it the double arrow button above the enter sign? LOST!
On most calculators, the equal sign role is played by the ENTER key. When the key is pressed, the calculator performs the calculation and displays the result.
Nov 08, 2015 | Office Equipment & Supplies
How do I read the result of my pregnancy test? I am getting so stressed about it that I just cant understand the instructions.
Not all pregnancy tests are the same but there are usually two ways of getting a positive result:
1) Some tests just show a clear vertical line in the control window and if you are pregnant you will also get a clear vertical line in the result window.
2) Some tests show a vertical line in the control window and a "-" sign in the result window if you are not pregnant and a "+" sign in the result window if you are.
All pregnancy tests come with instructions and usually they have pictures explaining the results. You can probably hold your pregnancy test alongside the leaflet if you are confused and it should clarify the result for you.
Mar 04, 2013 | Health & Beauty
Casio FX-115ES Scientific Calculator
I have done the calculation using the the shortcut key [x10^X] to enter the exponent,and I got the correct result.
I also did the calculation by explicitly typing the 10^10 factor and I obtained the correct result.
The syntax error may come from your using the minus - sign for subtraction rather that the change sign key (-)
Apr 06, 2012 | Casio FX-115ES Scientific Calculator
I get a "no signal"sign on my TV screen
this is as a result of the fact that your aerial antenna is either not properly connected or is bad and as a result cannot receive the signals that the tv would use, it could also be as a result of the wrong positioning of your aerial antenna or your tv being tuned to a wrong frequency. my advice is that you try to tune on all other bands and frequency to enable you detect if your antenna is properly placed or not.
Nov 19, 2010 | Dell Computers & Internet
How do i make the log button negative?
Enter the number, then press the LOG button. Once result is displyed press the change sign key. If result is positive, it will become negative. If result is negative it will become positive. The Change sign key is the one with + -, located between the . and the = on the bottom row of keys.
Apr 01, 2010 | Texas Instruments TI-30XA Calculator
Please explain which buttons to push on TI-36x solar calculator to find the pKa of benzoic acid. the Ka for benzoic acid is 6.5 X 10 to the -5th ? (Sorry I don't know how to type the exponents for you)
You need the [EE] key to enter powers of 10 exponents.
You need the change sign key [+/-] key.
You need the [LOG] key.
pKa: 6.5 [EE] [+/-] 5 [LOG] [+/-]
There are two change sign: The first (either before or after the exponent 5), the last is entered after you press the log key , so as to negate (make negative if result is positive, and make positive is result is negative) the value.
The result should be 4.1870866 or 4.19
Mar 08, 2010 | Texas Instruments TI-36 X Solar Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
How do I proform the -log of a number ie -log(1.2 X 10-5) to find the pH
The pH is defined as the negative log in base 10 of the H+ (H3O+) ion concentration. The concentration of your solution is 1.2x10^(-5). You calculate the log of 1.2x10^(-5) which is -4.9208188754, let us just say it is equal to -4.921.
Once result is displayed press the change sign key (-) or on some calculators [+/-] and calculator will take the negative of the result.
So your pH is about 4.921
Another less efficient way to do it is to enter
0-log(1.2x10^-5) [ENTER]. The result will be positive.
The change sign (-) is smaller than the regular MINUS sign. It is used with negative exponents and to change the sign (hence its name) of a displayed result.
Oct 06, 2009 | Texas Instruments TI-30XA Calculator
Sign in problem
You will need to uninstall the messenger from your computer and then re-install it to resolve this issue
Please revert with the result
Sep 01, 2009 | Yahoo Messenger
Yahoo massenger
I cant sign on my yahoo massenger:) its return me back to sign in area ..
I tried too many times and i reinstall the massenger again but without result
please help me
thank you
Regards
Jul 06, 2008 | Yahoo YHT-630 System
badoo Meet New People on Badoo Logo
97 people viewed this question
Top badoo Apps Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a badoo App Expert? Answer questions, earn points and help others
