Question about Singer Sewing Machines
My singer touch n sew model #645 is not drawing up the lower thread. How can I fix?
Manual is missing, not sure what adjustment can be made, if any. The machine was working and just quit drawing up the lower thread.?
  • Singer Master
  • 1,860 Answers
Here is a link for a free manual, also try changing the needle, make sure the bobbin is turned counter-clockwise, even try a different bobbin. try rethreading the sewing machine, also be could be a timing problem.
http://www.singerco.com/uploads/download/794_white-645-x.pdf
Posted on Dec 13, 2014
Singer touch sew 645
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Oct 11, 2013 | Sewing Machines
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
I have a singer sewing machine model # 758 touch n sew and I cannot find how to set the bobbin thread tention. The thread bunches up under the bottom plate and adjusting the upper thread tention does not...
Hi, welcome to fixya, maybe I can be of some help
I checked on singer website & they have a free downloadable instruction manual in PDF form just follow the these steps
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 758 )& click search
the second one is free
Sep 10, 2011 | Singer Sewing Machines
I lost my manual for singer model 4525 and am not sure I am threading it right do you have a diagram, also how do I adjust the tension?
found this for a 4526 - it could be very similar to your machine.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_4526_4528_4530_threading.htm
there is also good general machine help on www.sewing.about.com which gives generic threading help, trouble shooting etc.
Tension is usually controlled by a dial on the top thread, and a little screw on the bobbin case on the bottom thread. However, if you adjust either, just small increments is best to avoid making things worse. Top tension usually set to 5 or middle number and bottom tension shouldn't often need touching.
Apr 10, 2011 | Singer Sewing Machines
How do I load the bobbin on a touch and sew model 775
To thread the bobbin, open the slide plate, make sure the machine is threaded all the way up as normal, take the thread and wind it round a few times round the presser foot screw, push the little lever over near the bobbin to raise the winder, slowly press on the foot control and it will wind the bobbin, when you have enough thread, close the slide plate and draw the thread to the back of the machine and start sewing.
Oct 13, 2009 | Singer Sewing Machines
How to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Jun 13, 2009 | Singer Sewing Machines
Doesn't draw up the bobbin thread
Sounds like a timing problem. Can only be fixed by a technician
Apr 11, 2007 | Singer Quantum 9910 Computerized Sewing...
Sewing Machines Logo
90 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
