Question about Water Heaters
I got vokera excell 80 sp boiler ,after above tamprature 70 its turn off then i have to turn off after 20min i turn on then it work but again after som e time it cut off pls help
I change all the parts like domestic heat exchanger
  • vikram
    vikram Dec 15, 2014
    i have vokera excell 80 sp boiler ,the problem is when i turn on its work perfectly, but when temprature goes above 70 it cut off and then no hot water or no central heating. but ater 20min so when it cold then it work again pls tell whats the problem thanks Attach: Get more points i have vokera excell 80 sp boiler ,the problem is when i turn on its work perfectly, but when temprature goes above 70 it cut off and then no hot water or no central heating. but ater 20min so when it cold then it work again pls tell whats the problem thanks Attach: Get more points Video Photos Link Replacement PartsVideo Photos Link Replacement Parts
    Problem Solver:
  • 5 Answers
It could be the boiler is overheating and has to cool down before it can come back on. Look at the pump and make sure it is on speed 3, also drain some water and make sure it isnt dirty if it is you could have a blocked system that requires powerflushing.
Posted on Dec 15, 2014
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Check internal fuse un main circut board
Sep 29, 2013 | Water Heaters
Hi. Had a code 10 on my Vokera UNICA HE boiler. This was due to the overflow pipe freezing up. The pipe has been disconnected from the boiler and the boiler pipe is now dripping into a bucket. However, the...
I had the same problem. There's another clear rubber pipe underneath, that runs from the front right to a pump in the middle. I had to pull it off and dry it with a hairdryer before mine would light properly. Blast into the hole the pipe came off too to dry the sensor if there is one.
Dec 20, 2010 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
Nov 05, 2009 | Water Heaters
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
Vokera mynute 14se lockout reset button on
Has the boiler cool down? Try turn the power off for a few minutes and see if that will work.
Mar 14, 2009 | Water Heaters
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
