Question about Sanei Sainei N83 Deluxe 8 Inch Android 4.0 Tablet with Dual Camera IPS Capac
My tablet sanei n83 wont turn off
Wont turn off just keeps rebooting
I have an sanei n83 tablet but battery is dead after an hour
you probaly have to replace the battery thats actully inside the tablet itself
Nov 01, 2014 | Sanei N83 Dual Core RK3066 1.6GHz 8 Inch...
Sanei tablet not switching on
It's normal for a device to heat up during use and charging. As long as it's not too hot to hold, there isn't a problem. If it is hot enough to burn you I'd replace the battery
Dec 08, 2013 | Sanei N80 8GB Allwinner A10 Cortex-A8...
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
How do i do factory reset on sanei n91 tablet
How do i do factory reset on my daughters sanei n91 tablet she lost pattern lock and had tablet in flight mode so cant recover from email holding power and volume does nothing for reset.HELP
Mar 07, 2013 | Tablets & eReaders
Sanei n10 manual english
i have sanei n10 tablet and i lost the password and google accaunt what can i do ?
Jan 21, 2013 | Easy SANEI N10 Android 4.0 Tablet PC 10.1...
Sanei n77 android tablet doesn't have reboot button
I found a solution on youtube. You might press the power button for 5 to 10 seconds. The tablet will turn off. Then you press the power button again to turn the tablet on (3 secs), and that's all.
Hope it works.
Jan 18, 2013 | Sanei N77 Deluxe Tablet PC
Sanei Sainei N83 Deluxe 8 Inch Android 4.0 Tablet with Dual Camera IPS Capac Logo
Top Sanei Tablets & eReaders Experts
Are you a Sanei Tablet and eReader Expert? Answer questions, earn points and help others
