Question about Toys
I have a DMZ Shark II 3.5 CH Remote Control Helicopter and cannot get it to fly. The manual says that you need to bind the transmitter to the helicopter by turning on the helicopter, turning on the transmitter and then pushing the throttle control forward and then backward. It does not work. Nothing happens but flashing lights on the transmitter. Manual says that once the process is complete, the light on the transmitter will stay lit, it just keeps flashing.
micromatikal
  • 2777 Answers
SOURCE: Brookstone Silver Bullet Helicopter: When I
This is a battery fault, unfortunately pretty common. How old is this helicopter? It may still be under warranty.
Let me know, there is not really much of anything you can do on your end... you are doing everything correctly for sure.
Tim
Posted on Oct 09, 2010
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Posted on Dec 26, 2010
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SOURCE: Hey I recently just bought
The problem is the battery, I just got one for Christmas and overcharged the battery. I put a new one in and it works. The manual says never charge over 90 minutes.
Posted on Dec 27, 2010
SOURCE: I purchased the S006G Syma helicopter for my son
this happened to me push the trotle up then down the light should stop blinking and dont try to fly outdoors try gym if poss or warehouse plenty space
Posted on Jan 06, 2011
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
Front led light just blinks
Make shure transmitter is on and ready BEFORE powering heli and let rest the heli without any mouvement while and after powering up ( gyro setup ). Receiver maybe need to be bind for it to work, look for binding procedure in manual.
Nov 24, 2013 | SWANN Micro Attack Military Blue Gyr
Syma S026 instructions
We have a free copy available on our website.
Free Syma Helicopter Manuals
Kind regards, Julian.
rccontrolfreak.co.uk
Mar 05, 2013 | SYMA Toys industrial Syma S026 Micro...
My helicopter 9053 will not connect to my controller
The receiver is not binding to the transmitter. Make sure the batteries are in good shape in transmitter. I'm assuming it's a 2.4GHz radio frequency.
When you are about to fly, turn transmitter on first after 4-5 seconds turn
heli on or plug battery in on heli. In the manual there should be a page describing radio binding. It will describe on what gimbles to move and
in certain sequences to complete the process. When the light on transmitter stops flashing means the binding process is complete.
Hope this helps.
Dec 15, 2011 | xheli 9053 Outdoor Volitation Metal...
Hello, just been given a syma s006 for xmas, charged it up for max 110 mins as indicated in manual, though LED never came on to indicate full charge. LEDs do come on flashing when switched on at model. New...
try this,switch the helicopter on,then make sure the left controller stick is fully down then turn the controller on,move left stick fully on then fully off should be ready to fly,have fun
Dec 27, 2010 | xheli 3 Ch Syma S006 Alloy Shark RC Remote...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Throttle goes wide open
Its is probably a faulty potentiometer in the transmitter's throttle channel. Take it back to the store if possible otherwise see if you can get another transmitter and bind it to your helicopter. The binding process will be in your instruction book.
Feb 28, 2009 | Esky Flight Simulator R/c Helicopter Kit
Toys Logo
69 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
