Question about Ovens
I need to know where the fuses are located for oven. Oven no longer turns on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
Lift up cook top and check under there, by controls
Posted on Dec 13, 2014
Why does the oven time flash but the oven won't turn on?
power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
Servicing FusesIf the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
May 09, 2015 | Ovens
Oven and grill stop working no indication lights even turn on
Hello,if the whole oven longer then first see if there is power if it is to supply the fuse, which can be measured volt meter but maybe there will be one more heat than it is to heat that I helped, maybe would help if I could type.
May 02, 2013 | Bosch HBL 435 Stainless Steel Electric...
Where is the thermal fuse located on an electric whirlpool in cabinet oven?
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks,
    Oct 09, 2010 | Whirlpool RBS305PD Electric Single Oven
    Hi there. I need to change the fuses on my oven,
    hello,
    Instruction below.
  • thanks and thanks for visiting.
    Oct 09, 2010 | Ovens
    Bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
    After usung the self cleaning function the oven no longer works
    Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
    Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
    Oven does not Bake, Heat Up
    Replace the oven glow bar igniter. If you post an exact model number (located on sticker behind lower drawer) I can give you a part number.
    Sep 02, 2008 | GE JGRP17 Gas Single Oven
    SINGLE OVEN MODEL # RBS305PDQ16
    Probably refering to a thermal fuse. This fuse opens when heat is too high. Some of these ovens had a kit where you replaced the cooling fan, fuse and shimmed hinges to correct problem. You can access fuse by removing oven from wall. It will be located on back of unit. You can try replacing just fuse. It will probably be ok for bake and broil. It may happen again during clean.
    Oct 23, 2007 | Whirlpool RBS305PD Electric Single Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
