Hello.i have a tv plasma neovia neopl4200es but
Hello.i have a tv plasma neovia neopl4200es but inside is all samsung.i have a problem with the display because i don't have colours with it should be,and the image is a little bit flashing Before was working good but started to flash a little bit and now is it like this.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Sounds like supply voltage problem to its display panel. Every plasma display panel will have its own Va & Vs voltages; which will be marked at the silk screen on the display panel itself. It might differ from panel to panel. Even a slight difference in these voltages, will cause unexpected display nature. This is true to all Plasma TVs; irrespective of its brand and screen size.
Adjustment to these two voltages are there with its main power supply regulator board. You should be fully aware about these adjustment; I recommend.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 13, 2014
SOURCE: Vizio P4 Plasma TV, won't turn on
if your vizo p4 blinks red 10 times its your power supply board ckeck your two fuses on the board,if those are not bad change your power supply board if you can find a board for that model vizio p4 .the phillips tv uses the same board
Posted on Oct 15, 2008
SOURCE: 42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Posted on Nov 15, 2008
SOURCE: samsung 42' plasma tv,screen keep flashing, blurry,no pics
I'm not really sure what causes this but I might be able to help.
I have an LG 42 plasma which had the same problem. In my case I removed the video and the tuner board (they both were mounted on the same frame which was screwed on the tv chassis) and installed them in a "wooden box" so that there would be no electrical contact with the rest of the chassis except from the cables connected to them. It now works fine.
Posted on Feb 23, 2009
  • 11 Answers
SOURCE: sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Posted on Apr 07, 2010
SOURCE: 50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
Posted on May 05, 2010
Hello there, I have a 50" Samsung Plasma TV. There is weird horizontal colours at the bottom of the screen. Can this be fixed eazialy? Thanks Jodie.
I've had this happen recently. Can it be fixed, yes. However, it takes a good amount of work. Worse case senario, if you can find no one who can fix it, you would have to get another tv as this wold be a problem with the hardware of the tv.
Dec 11, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
I was going to get a plasma TV specifically the Samsung PN50C6500 and i was wondering if the whole thermal expansion controversy problem was over and samsung had become more reliable and this problem had...
No,don't buy plasma tvs any tvs make or tvs brand.Don't buy any kind of tvs using plasma gas as for plasma screen panel as a power sourced if u play major hours of gaming on the plasma tvs,u will still have thermal expansion problems but less.Plasma tvs still have major problems,with screen BURN IN problems though.
Aug 22, 2011 | Samsung PN50C6500 50 in HDTV Plasma TV
Dear sir are samsung dealer/supplier for large format display,our fern is supplying samsung item to university of kashmir ,now is issue is cable tv is not working on lfd model no p42h2 on the other hand...
Hello
You are talking about the plasma display of Samsung [Samsung Syncmaster] I understands. Specify the connections you have done to it to receive cable TV with this set. I can/t see any description about the reciving system [ PAL, SECAM, NTSC4.43, NTSC3.58] etc, from the manual of your display. Here in India, system adopted for all type of transmissions is PAL BG. Will your Plasma Display is compactable with this system/ If so it must rreceive the Cable TV here in India. Otherwise a converter may be needed. Please send me details of your plasma display reciveint system. Is it multisystem comatable? Give me details plelase. Give me the connection details that have don with that display also. OK.
Feb 27, 2011 | Samsung P42H 42 in TV
Red colour picture on plasma TV
It might need the color to reclibrated, if that does not work, a gamma electronic board need to be replaced
Jan 06, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
I'm connecting my laptop to my plasma tv to watch
It sounds like the cable is faulty. I presume it is a VGA cable as these are prone to wires breaking inside and colours going missing. Try bending the cable around a bit esp. near the connectors and see if the colour flashes on and off as you do this. If so you might be able to temporarily fix it if you can find a position for the cable where the colours are all working and tape the cable in this position. It might also mean than a pin is missing in one of the connectors.
Either way, I reckon you are going to need a new cable.
Jul 18, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Pink picture with no green
take the color to b/w and retune
Apr 23, 2009 | Samsung PN42A450 Plasma TV
Problem with samsung plasma tv
hello ive just bought a samsung plasma off my friend and its about a year old and yesterday i set it up and get a fine picture untill about a hour or so of being on it starts geting blue sparkles round the outside of the tv mainly on the left side and seems stronger when sport is on ive tryed doing different things but nothing seems to work?i have also bin told that plasma tvs have to have gas put in them every so often is this true?i dont no which samsung model it is but it is 42inch and is full hd ready and is black with the round circle on the front of the tv can you help me?
Dec 19, 2007 | Samsung HP-S4253 Television
NEC plasma television
hi jubbi, actually i'm not sure your problem you describe. So you can go to this link http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html see your plasma tv problem is it inside this guide?
Aug 31, 2007 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
