Question about Dyson DC40 Multi-floor Vacuum DC40
I bought the vacuum in August it was working perfectly until a couple of weeks ago when it started cutting out. It now won't run at all. It is clean in all the places that are accessible so I don't th
Cleaned it and recharged it.
  • Dyson Master
  • 9,587 Answers
Make sure the charger is working first. You can test it with a voltmeter. If it's ok then the power switch is the second most likely place. Then on to the motor and wiring. could be a loose wire connector.
Posted on Dec 13, 2014
  • Official Brand Answer
  • 2,572 Answers
Hi Peter, it's Jack at Dyson.
Your question is categorised under the DC40 upright section, but as you've mentioned recharging your machine I'm guessing you own a Dyson cordless vacuum?
If this is the case, we'd need to take you through some simple diagnostic checks to confirm which component is at fault. As you've only had your machine since August, it should be well within our 2-year parts and labour warranty period.
When you have your machine fully charged and easily to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) for further assistance.
We'll look forward to speaking with you.
Posted on Dec 17, 2014
My Dyson DC31 runs for a few seconds then cuts out and won't work at all. It is fully charged. We bought it just over 2 years ago and it has worked perfectly until now. It is clean and has no apparent...
Hi Jean, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC31. If it cuts out in use when it's fully charged, we'd need to take you through some quick diagnostic checks when you have the machine at hand. This will help our experts determine what may be causing the issue.
Please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 04, 2013 | Dyson DC31 Animal Bagless Handheld...
My vacuum is making a loud whirring sound and is hotter than normal.
Hi Kelsey! I understand how frustrating this must be. Dirty filters or a clog can cause the vacuum to change sound and be hotter than normal.
Here is a quick link to troubleshooting the excessive noise:
http://www.bissell.com/FAQDetail.aspx?id=1362&cid=ccsocial
Mar 28, 2013 | Bissell Cleanview Helix Bagless Upright...
I bought a bissel quicksteamer powerbrush multisurface 2 weeks ago used it once. Now it will not **** up the water it sprays fine but won't **** up
if you bought ot new.its under warantry, take it back were you bought it, you are covered under the sale of goods act the, shop has to fix the problem
Aug 16, 2011 | Bissell Vacuums
I have a DC25 that I just bought in Dec 10. The last few times I vacuumed the carpet, the beater bar worked on and off. Now it does not move at all. I took off the beater bar to see if there were any...
This is a good quality machine which I am sure wil last a long time in answer to your question make sure that the setting is set for carpet and not just flooring ..the head needs to be flat on the floor for the beater to work .I am assuming that this is quite new and therefore no wear to belts, also check no hair is caught around the bar sticking it, I have two daughters and this often happens to me ,,Good Luck.
Feb 27, 2011 | Dyson DC25 All Floors Bagless Upright...
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
May 13, 2009 | Vacuums
NO SUCTION COMING FROM BOTTOM OF VACUUM
even though the belt isnt broken you should replace it also make sure the height is raised up on the nozzle. try dropping a marble through the hose to double check there is nothing stuck ( the attachment hose and the small hose that runs to the floor )
Sep 07, 2008 | Hoover U5507900 Elite Rewind Bagless...
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor overheating
There is a filter on top of the motor as well. You will need to remove the plastic cover on top of the motor with a small screwdriver or other flat blade. On the front, you push in the clip and pull up ont he cover. On each side of the cover there is another clip - to pop those you put your flat blade into the angled tab and slide it around to the clip until it pops. Gently or you'll break the tab. Once the cover is off there is a purple tab in the center pull up and you will pull the HEPA motor filter out - similar in shape and size to the side, washable, filters. Clean or replace that.
May 27, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC40 Multi-floor Vacuum DC40 Logo
85 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
