I have a hotpoint washing machine WML730 and I have shredded white plastic in the load if washing. Do you know what could be the cause please?
  • Washing Mach... Master
  • 3,382 Answers
It could be part of your pump assuming you put nothing plastic in it.
Posted on Dec 13, 2014
3 Suggested Answers
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Try http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Feb 16, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
Posted on Dec 15, 2008
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
Hotpoint wma74 washing machine fills with water then does nothing will not run drum or spin
hello it sound like the brushes on the motor could be the cause 2 plastic blocks sit either side of the motor these are made of carbon and wear down can cause the motor to stop working also the other causes could be interlock on the door and module control board hope it helps
regards
shaun
May 24, 2011 | Hotpoint WMA74 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Loud clunking in final spin
Time for a new machine, fix is very expensive, machine needs basket support, called a spider, parts are about 300. 00
Apr 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Hotpoint washer not rinsing
If it is at the rinse or spin cycle it could be something trapped in the pump, for the water can't drain quickly enough when the machine starts to spin & the water gets forced back up through the soap dispenser as there is nowhere else for it to go. Check your filter too.
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf860
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
Please if you know the solution let me know
Shiya
Aug 15, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
