Question about Samsung Refrigerators
Samsung Frig water dispenser makes loud humming sound when dispensing water. This began after changing water filter.
Nothing. Don't know what to do. No error codes appear. It is only noisy when pouring water.
    Novelist:
  • 187 Answers
Check to see if you have rotated new filter in the engaged direction.
I have had a few filters that were defective and were not fully charged. If you have the reciept, take old filter back to retailer and see if you can exchange it for another one. Also, make sure you have the right filter model number. You can check the model number for the filter with your refrigerator model number at Searspartsdirect.com
Hope this helps
Posted on Dec 14, 2014
Hello, I have a frigidaire side by side fridge and freezer ( LGUS2642LF2). Water stopped coming out of the dispenser and the ice cubes are coming out but is taking a very long time. I first replaced the...
Good Morning Friend,
I understand that you are having trouble with receiving water out of the dispenser area of your Frigidaire refrigerator, model# LGUS2642LF2.I also see that you have changed the water filter as well as checked and replaced the inlet valve with no positive results, other than it sounds like it wants to dispense water and makes a humming sound. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored, try getting water out of the dispenser. If you are still having trouble, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your refrigerator not dispensing water. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
Water dispenser not working
Have you changed the water filter? they can plug up over time. The water tube can freeze in the door. To test this there usually is a disconnect under the freezer door side of the grill you can disconnect this and hit the water dispenser lever. If the door is getting water then it is frozen in the door. If not the water valve could be your problem there are two sides to the water valve one for the water dispenser and one for the icemaker. A last possibility is there is a water tank or tubing loop in the refrigerator behind the crisper this could have frozen.
Feb 10, 2014 | Refrigerators
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
Sam Sung French Door Refrigerator RF267 After one month, water dispensing slow, small ice cubes, cloudy water. What is the solution?
It sounds like the water filter needs changed. Yes I see It's only been one month. Also make sure you have good water pressure to the frig.
I hope this helps.
Aug 23, 2010 | Samsung RF265AA Bottom Freezer French Door...
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
My water dispenser does not give me water
1st make sure you got water to the frig.
defrost the frig by turning it off for 2 days with the doors open. Sometime the water freezes inside the door and the water dispenser doesnt work. the turn back on and see if you have water. every 6 months you should change the filter (it could be the problem too)
Mar 27, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
IWater does not dispense.
Good day,
The hum is normal. That's the water valve in the rear of the machine being activated.
Lots of plumbing to be checked.
Water line starts at the dispensing outlet in the door, and runs thru the door to the bottom of the hinged side.
From there it goes to the filter,
'From there it travels under the machine into the cooling reservoir mounted back of the fresh food section behind the crispers.
From there it travels back out and runs to the water solenoid mounted on the back rear of the machine.
One of these lines or their fittings has failed.
It's a look-see repair.
Also, there is a remote chance the water line running inside the freezer door froze, causing this problem, and would require the machine be shut down (unplugged) and the door be allowed to defrost completely.
Nov 16, 2009 | KitchenAid Refrigerators
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
I have an old Kenmore 26 side by side that dispenses water and ice. At one point it stopped producing ice and dispensing water. I changed the inline filter and it worked perfectly. Happened again shortly...
It sounds like you need to replace your water inlet valve , it is a dual valve for ice and water in the door and they go out often , the solenoid is not opening anymore , it is located where you hook up the water line.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Whirlpool GD2SHGX Refrigerator
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
82 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
