Question about Dryers
My bush tdv6w vented tumble dryer is not heating up
If it is stored outside, take a hairdryer out and heat into the filter area for 3 minutes. They are not designed to work below a certain temp (5 degrees I think). Mine stopped working on NYE and was just flashing lights. The temp went up to 7 degrees and it worked but only blew cold. I used the hairdryer on it and it now works perfectly. Good luck.
Posted on Jan 02, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If your dryer is an electric dryer, it is sounding like you have either a bad heating element or one of the two limit switches are open. The limit switch is an "overtemp" device to shut down the element if it gets too hot from air restriction. Lint build up in the blower and ducting is a major cause of restricted airflow across the heating element. Excessive tripping of the limit will result in an "open" limit switch and continual failure to generate heat. There should be one limit switch built into the heating package and the high limit will be located on the drum usually near the top, though there are some near the bottom of the drum as well. Any attempt to find and replace must be done with the power off as you are dealing with 240 volts.
If your dryer is gas fired, you've had a misfire probably due to a defective hot surface igniter or bad control module. Unless you are fairly capable of learning as you go, and have the basic tools for troubleshooting you probably need to call a sevice technician.
Posted on Dec 13, 2014
How do I attach the hose to the vent at the back of a Bush TDV6W
Vent hoses usually are attached with a clamp.
Oct 28, 2016 | Dryers
I have a tumble dryer bush tdv6b got from a friend not very old was working fine now its not doing anything apart from a slight buzzing noise tried the reset at the back does nothing thanks
MOST PROBABLY THE CAPACITOR BESIDE THE MOTOR NEEDS REPLACED. http://www.buyspares.co.uk/tumble-dryer/tdv6w/capacitor/product.pl?pid=4058219&shop=bush&path=864668&refine=capacitor&model_ref=8702213
Jan 31, 2016 | Dryers
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
I have a bush tumble dryer TDV6W and each time its switched on it trips the electric whats the cause?
guessing the heating element has shorted to ground . call for service.
Jan 17, 2015 | Dryers
I have a bush tumble dryer TDV6W but when I put it onto the extra heat part the botton flashes and cuts my electric out, whats wrong with it, its only 4 months old
Hi Margaret, 4 months old? warrenty problem! it may also be a shorting temperature sensor. How old is the wiring in your abode? Possibly circuit breaker faulty.
Dec 30, 2014 | Dryers
Bush tdv6w tumble dryer wont start just flashes lights and beeps
All these sound like good advice but in addition - there is a re-set button on the back of this machine, push it and see if the problem continues. If you still have the same problem after re- setting your machine please call their customer service line at 0345 640 2020.
Nov 25, 2013 | Dryers
My dryer is new it's leaking water and not drying clothes it's bush tdv6w
you have a plugged vent from the wall somewhere to where it goes to the outside , the way to tell is to unhook the vent hose run dryer through normal cycle and see if cloths dry
Nov 24, 2013 | Dryers
Dryers Logo
756 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
