How to clear error code f2 in ar5618 copier
I change the developer
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
checkitright
  • 1362 Answers
SOURCE: F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Posted on Sep 03, 2008
sir fixalot
  • 146 Answers
SOURCE: Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Posted on Nov 11, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: my 5316 copier keeps blinking F2 and willnot print
F2 - Black toner supply trouble
Try a different toner cart, remember to shake the cart. before installing. Power the machine on and off and check. Check the sealing tape has been fully removed from the cartridge as well as the green colored plug.
Also, if you have an original drum unit frame, change the frame with the new Modified version to prevent arching at the rear cover of the drum unit against the inside back plate of the machine.
Check that the black dev. tank is not low or empty, re-position both drum & dev. tank.
Pls rate - Thank you
Posted on Mar 02, 2009
My sharp ar5618 is showing f2-40. what should i do?
It is an error code. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 04, 2015 | Sharp Office Equipment & Supplies
How to clear error code f2-64 in sharp ar5618 copier
Unplug it for a full minute from the power & the computer & replug & start again aft a min.
Dec 13, 2014 | Sharp Office Equipment & Supplies
Go to the Manufacturers web site and view FAQ's & or e-mail them.
Dec 13, 2014 | Office Equipment & Supplies
My machine model AR5618s error code 2 and F than 64 what solution?
According to the service manual
F2-64
Content
Toner supply abnormality
Detail
When toner near end is detected with the toner supply time of 50% or less.
When the toner supply time exceeds 300%.
Cause
ATC sensor abnormality
Check and remedy
Replace the toner cartridge.
Replace the developing unit
Aug 24, 2014 | Office Equipment & Supplies
f2 mean toner chip disable.You should buy new one cartridge.There are easy to get only chip,please buy new chip and assemble this chip
Oct 20, 2013 | Office Equipment & Supplies
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
May 23, 2008 | Sharp AR-M237 Copier
23 people viewed this question
k24674
jasbo
jasbo
