Question about Electrical Supplies
I have a 6500 titan deisel generator and would like to know what you would set the valves at when adjusting them .010 ?
    Top Expert:
  • 22,167 Answers
Most exhaust on diesel will be 0.012 and 0.09 inlet. at TDC
Posted on Dec 13, 2014
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
I have a titan deisel generator and would like to know what egnites the fuel
Diesel engines ignite with pressure and heat unlike gasoline engines that use spark plugs for ignition.
Dec 13, 2014 | Cars & Trucks
What is the valve settings
If you have adjustable tappets the setting are usually .010" hot inlet and .12" hot exhaust. Start at 12 and 14 cold and recheck when hot. If you have hydraulic tappets there is no adjustment as they automatically adjust when oil pressure is achieved
Jan 26, 2013 | Cars & Trucks
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
Need to know original 4g37 engine 1.8 galant 1988 tappet valve clearance
intake .006
exhaust .010
jet valve "if applicable" .010
note:adjust when engine is hot
Mar 11, 2011 | 1988 Mitsubishi Galant
What oil do i need to use in my titan 6500 diesel generator?
a standard diesel graded motor oil is ok to use in these like 10w40 sj/a2 will be just right
Aug 07, 2010 | Garden
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
Which direction does the filter in the vacuum valve kit go
i think your talking about the reed valve thats in the valve sping cover housing. if so it should only go together one way and the reed valve should open up. hope this helps...good luck...
May 19, 2009 | Watts Onan Portable Generator - 5000 ,...
I need to know the vavle clearance of nissan z20 engine.
VALVE CLEARANCE ADJUSTMENT
Application In. (mm)
Intake .010-.013 (.26-.34)
Exhaust .011-.015 (.29-.37)
Mar 20, 2009 | 1995 Nissan Maxima
Valve adjustment titan
the valves are hydraulic, this means they are zero lash, no adjustment required.
Dec 14, 2008 | 2004 Nissan Titan
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
