Question about Denon DP-300F Turntable
Denon DP 300F turns extremely slowly.
I have a problem with a brand new one. Third disc, all of a sudden it turns extremely slowly. Like a minute per turn type of slow. Belt looks fine. Motor is slow. Do you have any suggestion ?
  • Denon Master
  • 5,487 Answers
If like what you say the deck is brand new you should contact the service center. They will attend to the matter free of charge. Web address follows:
http://denon.custhelp.com/
Posted on Dec 29, 2014
3 Suggested Answers
maklean
  • 1665 Answers
SOURCE: belt fell off
There are two main types of phonograph turntable drives still being manufactured today, the belt-drive and direct-drive systems; the names are based upon the type of motor system found in each.
In a belt drive turntable the motor is located under and to the side of the platter and is connected to the platter by an elastomeric belt.
The design of the belt drive turntable allows the use of a less expensive motor than the direct-drive turntable. Also, the elastomeric belt absorbs motor vibrations which would otherwise be picked up by the stylus.
Posted on Jul 18, 2008
  • 79 Answers
SOURCE: platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Posted on Sep 26, 2008
Brand new Denon DP 300F turns extremely slowly.
The turntable should be under warranty still so contact the makers and they should sort it out. Any tampering with it could void any warranty so don't let any unathoriesed person touch it.
Dec 13, 2014 | Denon DP-300F Turntable
How to adjust dp-300f speed
Both the owner's and the service manuals for your turntable are available for download:
http://www.vinylengine.com/library/denon/dp-300f.shtml
You only need to register (free) with them.
May 28, 2014 | Denon DP-300F Turntable
Have a brand new Denon DP-300F turntable that worked fine for the first two recods. Now when I use it the records sound as if they are playing in slow motion. Could there be an issue with the belt eve
It could, but it could be caused by something stuck inside it, perhaps from the packing or some other bizarre thing connected with it being transported to your home.
Feb 27, 2014 | Audio Players & Recorders
Running VERY slowly
The thing to do is to check the belt first, then look at things like is there a build up of grease dirt anywhere. Clean up the platter make certain no grease or dirt is the works causing it to slow down.
See also that the motor that drives the belt can turn freely and very easy by hand.
Jan 25, 2014 | Denon DP-300F Turntable
New DP 300 f with uneven speed ?
then you need to turn the potmeter , but since it is new, return it...
Jan 13, 2014 | Denon DP-300F Turntable
Denon dp-29F won't turn
hit it with a hammer...............
or the other option is to switch off the unit at the wall, then switch it back on again.
Dec 06, 2013 | Denon DP-29F Turntable
Denon DP-S1 won't read discs
It is possible that the drive has failed.
Nov 06, 2013 | Denon Audio Players & Recorders
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
Sync problem with denon dns3000
I'm having a similar problem with my denon dp-300f. It seems to *ever so slightly* increase or decrease in speed (and therefore pitch)...I might not even notice it very often if I wasn't listening to my favorites. I have not found a solution to this problem, but my hunch is related to the power source. Meaning: I think the voltage output by my apartment is slightly sagging (<120V, AC ~60Hz...which most appliances can deal with) and this affects the speed of the motor that drives the belt. I'm looking into isolating this factor. I'll let you know.
Nov 19, 2009 | Audio Players & Recorders
Denon DP-300F Turntable Logo
235 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
