Question about Microwave Ovens
I got two Diod on capacitor in my microwave One is TS01 and T4512H TS01 is grounded and T4512H is conected to both capacitor points in upside down series my question is what this circuit called and it's purpose and it's eqvillent diod becouse I am not getting the diod from market in india
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
There are no schematics on the boards available. You didn't mention if you tested the diode. Just replace the board.
Posted on Dec 14, 2014
  • anil kalel
    anil kalel Dec 15, 2014
    The diod one which is grounded I found most of the micro-oven, but the other one which is there on capacitor on both leads of capacitor what's the purpose of that one which is mounted on capacitor
3 Suggested Answers
electrodynam
  • 35 Answers
SOURCE: Micro is working only for 15-20 second
its overheating,the high temp overload will shut it off until it cools then it will let the unit work again.If it was the capacitor or the high voltage diode the unit would stop working,and not work again.
Posted on Mar 16, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Maytag MMV5156AAS Microwave won't heat and has hum/buzz.
A failed diode isn't the most common failure, but it happens. And sometimes it's due to bad magnetron or a bad connection.
If the capacitor fails, it almost always shorts, which results in a blown fuse whenever you hit "Start" to run the microwave.
The magnetron on this model should have a 5-year warranty, in case that's relevant. Your owner's manual is here.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/cap_test.html
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
Posted on Jun 30, 2009
T4512h diode
If it's not shorted and doesn't have a burn or chunk blown out, it's probably good.
Diode test info here:
http://www.microtechfactoryservice.com/diode.html
Here's the battery-assisted test you're referring to (6V is okay):
Jan 16, 2014 | Microwave Ovens
My microwave just stopped working. It was working fine.
you can check fuse inside ok or not.
High voltage diod and capacitor OK or not.
micro oven can hold a dangerous amount of electric charge (15000V) for 15-30 minutes even after unplug.
so be careful
go for professional technician.
Jan 29, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Dec 31, 2009 | Kenmore Microwave Ovens
JVM1650SH02 keeps shorting out after a couple seconds
> but he would also replace the capacitor and diod when replacing the mag tube
Most of the time replacxing them all is done due to ignorance about how to actually test devices, a mistaken notion that it's somehow necessary, or to pad the bill.
The diode may be necessary in some cases (if it tests bad) but the capacitor is almost certainly not needed.
When a capacitor fails, it almost always shorts. If so, the fuse would blow when you peress "Start" to begin cooking.
I've rarely (if ever) seen one fail without shorting.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then GE manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you're doing this yourself, G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
> Can I just replace the mag tube without also replacing the diod and capacitor?
Almost certainly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 11, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave is not heating
If it makes a humming noise it is the magnetron or diod or capacitor.
Please provide more information like a model number and more specific symptoms.
Jul 31, 2009 | Microwave Ovens
Mar 16, 2009 | Microwave Ovens
MICROWAVE D9023EFL BRANDT MODEL
Brandt is overhauling their Web site, so i would call 0870 240 8095 for parts.
If you are not in the UK, please let me know.
Aug 09, 2008 | Brandt Microwave Ovens
Completely Dead
there is a fuse in the top right hand of the microwave it will burn out when the Capacitor goes bad it will burn it out replace the Capacitor diod and fuse
Jan 05, 2008 | Thermador MBBS Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
