Question about Panasonic Televison & Video
I have a panasonic dmrex77 ,has been great for 6 years ,now won't turn on ,fuse and power cord ok , it's such a good peice of machinery I don't want to throw it . Powerlight wont come on , there is a
Looked for dry joints ,checked fuse and powwer lead .
    Top Expert:
  • Panasonic Master
  • 74,468 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 13, 2014
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
My panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and reconnect . A replacement of power cable or use another power outlet is another good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
Dec 10, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
I have a Panasonic DVD Video Recorder model DMR-E85H manufactured in 2004. It has worked perfectly for all these years but now won't power up at all. I have checked the only fuse I could find inside...
The power supply board is the problem, one of the most common failure is the 1000uf capacitor "open" located near the power transistor that is heat sinked, value may be higher or lower with one or two caps, the second possibility is the power transistor may be open or shorted.
Jun 24, 2011 | Panasonic DMR-E85H DVD Recorder
Panasonic NV L28 does not power on.
the most probable cause of malfunction in your equipmenty is a a electrolitic capacitor in the power source. The capacitor is marked with a value of 1uF 400V in the primary side of the PSU. Replace them and the unit is alive for 20 years more!!!
Greats and good luck!!
nachotebar@hotmail.com
Jul 22, 2009 | Panasonic Televison & Video
Does not turn on
If it is a touch pad operated ac then the fuse is sammiched in the middle between the touchpad and the board. Pretty slick ain't it? .3 amp is the size i beleive but don't hold me to dat.
Jul 17, 2009 | Panasonic CW-C200NU Air Conditioner
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Televison & Video Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
