Question about Health & Beauty
Have Phillips phillyshave cool skin 6760 but no clue which outlet to plug in
I have 2 sockets I can plug into 115 and 230 Which do I use
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
The head of the power cord states that the voltage can be 100-240V
Posted on Dec 24, 2014
Phillips hdtv will not turn on
Look for any loose contacts in RC jacks/sockets/Cable.
Check your power outlet for any loose contacts. Connect it to a different power outlet. Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | Televison & Video
2002 Eclipse: My right headlamp goes out once in awhile. I get out a give it a good thunk with my hand and it turns on. Some say its a loose connection at the plug. I took out the bulb and it appears...
BULB SOCKET COULD BE BAD OR BULB GETTING READY BLOW OUT.BUY A NEW HEAD LIGHT BULB.WEAR CLEAN GLOVES WHEN HANDLING THE HALOGEN HEAD LIGHT BULBS. BECAUSE OILS FROM SKIN OR HANDS WILL CAUSE HALOGEN BULBS TO OVER HEAT AND BLOW OUT.
Sep 25, 2011 | 2002 Mitsubishi Eclipse
Steps on removing and replacing radiator on my 1999 jeep cherokee sport 6 cyl. stright
Things You'll Need
  • Waste oil collection pan
  • Needle nose pliers
  • Phillips head screwdriver
  • Wrench set
  • Socket set
  • Antifreeze
  • Water
  1. Draining the Cooling System
    • 1 Locate the petcock valve on the lower right corner of the radiator and place a waste oil collection pan underneath it.
    • 2 Open the petcock valve by turning it counterclockwise, using needle nose pliers.
    • 3 Wait until all the coolant has drained out then close the petcock valve by turning it clockwise.
    Removing the Radiator
    • 1 Loosen the hose clamp that connects the upper radiator hose to the radiator using a Phillips head screwdriver. Then pull the upper radiator hose off the radiator.
    • 2 Loosen the hose clamp that connects the lower radiator hose to the radiator using a Phillips head screwdriver. Then pull the hose off the radiator.
    • 3 Unscrew the transmission cooler lines from the radiator (automatic transmission only) using a wrench.
    • 4 Unscrew the bolts that secure the radiator to the core support, using a socket.
    • 5 Lift the radiator straight up to remove it from the vehicle.
    Installing the Radiator
    • 1 Lower the radiator into position behind the core support. Be careful: the cooling fins are thin and can be easily damaged.
    • 2 Screw the bolts that secure the radiator into the core support. Tighten with a socket.
    • 3 Thread the transmission cooler line fittings into the radiator. Tighten with a wrench.
    • 4 Slide the lower radiator hose onto the fitting on the bottom of the radiator. Slide the hose clamp over the fitting and tighten with a Phillips head screwdriver.
    • 5 Slide the upper radiator hose onto the fitting on the top of the radiator. Slide the hose clamp over the fitting and tighten with a Phillips head screwdriver.
    • 6 Fill the engine with a 50/50 mix of antifreeze and water.
    • 7 Run the engine and visually inspect for leaks.
Aug 30, 2011 | 1999 Jeep Cherokee 4WD
Hello i have phillips cool skin shaver cant remember proper model of it but its the one with stand charge which fills up shaver with this skin balm and also there i small stand charger as well and none of...
Hi pi finch,
Below are some troubleshooting steps for this issue. If you have any questions or need additional assistance, Consumer Care can be reached at 1-800-243-3050.
Question Why does the shaver not charge when I place it in the refill & charge station? Answer
  • The adapter has not been properly inserted in the wall outlet
  • the small plug has not been inserted properly in the refill & charge station.
  • There is no electric contact between the refill & charge station and the shaver because the shaver has not been placed properly in the station. First put the bottom of the shaver in the station. Then push the shaver backward till it locks into position with a click. The indication lights on the shaver and the station light up to signal that there is proper contact between shaver and station.
  • There is no electric contact between the refill & charge station and the shaver because the contact strips are dirty. Clean the strips with a damp cloth.
Hope this helps. If so, let me know by rating this solution.
Aug 05, 2011 | Philips Health & Beauty
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
Specs on the PMBC NIMH battery for replacement in a phillips 5811XL
from where i can buy a battrey for my Philishave cool skin HQ 5660
Aug 09, 2009 | Philips Philishave Cool Skin HQ5620
Power supply light is red
This issue occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply will turn itself off if one of the following conditions is true:
  • There is too much current
  • The voltage is too high
  • The temperature of the power supply is too high
Under these conditions, the light on the power supply turns red.
Step 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or that it has already overheated. If the power supply light is red, follow these steps:
  1. Make sure that your Xbox 360 console is turned off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall socket.
    For more information about how to disconnect the Xbox 360 power supply, click the following article number to view the article in the Microsoft Knowledge Base: 906205 (http://support.microsoft.com/kb/906205/ ) How to connect and disconnect the Xbox 360 power supply
  3. Let the power supply cool for several hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall socket during this time.
  4. After the power supply has cooled for several hours, reconnect the Xbox 360 Power Supply to the console and to the wall socket.
If the power supply light is still red, go to step 2. Step 2: Make sure that the power supply is plugged in correctly loadTOCNode(2, 'whattotry'); If the power cord is plugged in to an extension cord, a surge protector, or a power strip, the current or voltage that flows through the power supply may not be correct. Make sure that the power supply is plugged directly into a working wall outlet.
Step 3: Plug the power supply into a different wall socket loadTOCNode(2, 'whattotry'); Try a different wall socket. Ideally, plug the power supply into a wall outlet that is elsewhere in the house.
Jul 16, 2009 | Microsoft Xbox 360 Console
Charged for approx. 6 hours then wouldn't work
I copied this from the Philips website... this took me FOREVER to find! Their site isn't the easiest to find products on...
"Insert the small plug into the shaver and put the powerplug in the wall socket. When you charge the appliance for the first time or after a long period of disuse, let the shaver charge for at least 16 hours. Remove the powerplug from the socket and the small plug from the shaver as soon as the batteries have been fully charged. Ignore the charge indicator when you charge the batteries for the first time. The batteries are completely new and need to be charged longer than the time indicated by the charge indicator to ensure that the back-up capacity is fully charged as well."
I hope this helps. Please remember to rate my help! I would greatly appreciate it!
Apr 26, 2009 | Philips Philishave Cool Skin HQ6760/HQ...
Health & Beauty Logo
41 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
