Question about HP Office Equipment & Supplies
I have HP Color LaserJet CP1515n Printer wanted to configure on domain base network . Just need to know the IP address of this printer????
    New Friend:
  • 21 Answers
Status TheStatusfolder contains links to the following main pages.
  • Device Status. This page indicates product conditions such as a jam or an empty tray. After you correct a problem, clickRefresh statusto update the product status.
  • Supplies Status. View details such as the estimated percent of toner remaining in the print cartridge and the number of pages that have been printed with the current print cartridges. This page also has links for ordering supplies and for finding recycling information.
  • Device Configuration. View a detailed description of the current product configuration, including the amount of memory installed and whether optional trays are installed.
  • Network Summary. View a detailed description of the current network configuration, including the IP address and network status.
  • Print Info Pages. Print the Configuration page and other information pages, such as the Supplies status page.
Posted on Dec 13, 2014
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Printer cannot be found in network. reset IP address and jetdirect menu, still nothing
Make sure they both router and printer are set to DHCP. Once you can ping the printer based on the IP, you can re-install it on the computer. Again, based on the network IP address. The printers IP address should also be noted on the DHCP list on the routers web admin page.
Feb 25, 2013 | HP Color LaserJet 3800
What is the default ip address of the printer hp laserjet 4250n?
There is no default IP address on HP printers with Jetdirect print server card.
You set the IP address in the printer's network settings. The IP address need to be set to match your network's address range.
To configure the HP network printer to work on your network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Dec 14, 2010 | HP LaserJet 4250n Printer
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
I purchased an HP LaserJet Printer back at the end of 2006. I was able to use this printer under Windows 7 until I attempted to use it with a different Internet configuration that requires DHCP to be...
Hp2600n is host based. It would not work properly with DHCP. If the printers use DHCP, I would suggest assigning a manual (static) IP to the printers and see, if that makes a difference.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 13, 2010 | HP Color LaserJet 2600n Printer
HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
Sep 02, 2009 | HP LaserJet 4050tn Printer
Cant print in my network
I am having a similiar network problem, I setup the 2600n on my small-office network, plugging it into an 8 port switch along with a computer and IP camera....then connected the switch to the default router...this worked for a while as my router provided the printer an internal IP, but somehow the IP reset itself to an external IP,and print jobs I send now to the 2600n from my network will not print. I can't seem to access a configuration window to set a static IP address my router will recognize.
Feb 15, 2008 | HP Color LaserJet 2600n Printer
HP LJ p2015dn IP configuration using HP Toolbox FX
Hi Basically I powered up the printer unplugged the network cable. Reconnected and waited 2 min. Pressed green button till first sign of green light flashing. The printer then printed out a printout which shows ip address on first and third page. I then used internet explorer to change printer from DHCP settings to fixed. just type new ip address on internet explorer address line. PC and printer must be on same network.
Nov 20, 2007 | HP LaserJet P2015dn Printer
74 people viewed this question
Seeker5211
Seeker5211
